This popped up on the C170 board today. Thought it was interesting. I know folks have been getting FAs for years, but there usage might finally be covered by FA Dodge's STC.
http://fadodge.com/images/pdf_files/FAA ... rcraft.pdf
Hottshot wrote:I know there is an STC in the works for the 850's on the 170's ....
Additionally, use on the original main gear wheels of Cessna 170 series is approved due to similarity of application.
Bowtie_1961 wrote:Additionally, use on the original main gear wheels of Cessna 170 series is approved due to similarity of application.
Does the "170 Series" include the C172's or C175's that have been converted to tail draggers?
Are they not considered "170 Series" as well!!!
dogpilot wrote:Yes it would be challenging to make your own 8.50 x 4 tires, as it seems no one else does. At least for 180/185 the 180/185 club has an STC for a whopping $2.00. The letter, if you read carefully, still requires you to file an ACA-337 when you swap with the amended W&B. So you might as well just get the STC, which covers many wheel brake combos. It is a heck of a lot easier to file a 337 referencing an STC than explain to your PMI a letter from another FISDO.
I have had them say, "I don't buy that." Then refuse the mod. It is their region, go ahead, push on that amoeba. I'll just pay the $2 and rock on, don't need the physic energy drain in explaining things to special folks in the US gov.
http://www.skywagons.org/club_store.asp?menuID=18
soyAnarchisto wrote:I'm not a type member. Could someone click on this link and post the STC letter with all the brake/wheel combinations this $2 STC provides?
Is anyone out there running the non-standard combination of McCauley 6" wheels with Cleveland brakes?
Thanks.dogpilot wrote:Yes it would be challenging to make your own 8.50 x 4 tires, as it seems no one else does. At least for 180/185 the 180/185 club has an STC for a whopping $2.00. The letter, if you read carefully, still requires you to file an ACA-337 when you swap with the amended W&B. So you might as well just get the STC, which covers many wheel brake combos. It is a heck of a lot easier to file a 337 referencing an STC than explain to your PMI a letter from another FISDO.
soyAnarchisto wrote: I will once I am an actual owner. They won't let me in the club until I'm an owner anyway.....
