A1Skinner wrote:No pictures of the young women?...
Helio295 wrote:Just a quick point of clarification. The prop on the Helio turn Slower (2170 prop RPM at 3400 engine RPM) at full power than anything comparable. The gearing slows the prop allowing a much longer blade and significantly more torque. Slower blade but closer to the water because it is so long. Don't fly floats so how does that affect water spray?
I think the engine is a really great mate to the airframe. The gearing and associated torque is a lot of what makes the plane. 1600+ lbs of thrust on a Helio at full power. Much more than a IO-520 mated to a 401 or a MT. Hard to find parts for expensive to operate, but WOW, it makes thrust!
dogpilot wrote:You are quite correct about he prop RPM. The blades are quite long and did seem to pick up quite a bit of spray, even with the spray extensions on the EDO floats. It was a bit loud with the engine turning at such high RPM. He was bemoaning the wear on the blades and the overall high price of blades. I have no idea if he has an STC restriction on prop selection with the EDO's. On mine, I am restricted to using the Hartzell vice the McCauley on floats. You really needed to keep the yoke in your belly to keep the spray down when taxiing at any speed. The EDO's seemed to not have very much reserve bouncy on that installation. Every time you his a swell you would get swirls of mist off the prop. I suppose they may be the only ones certified for that aircraft. All the data we used came out of the Air Force U10 manual, which had the float supplement. All considered, 4000 lbs on those floats seemed, to my unlearned eye, to be a bit small. This is the sum total of my actual flying floats. Aside from that, my experience it is all maintaining them and the aircraft.
