Backcountry Pilot • Fine Wire Plug Cleaning?
9 postsPage 1 of 1
Recently made the switch from massives to Tempest fine wires. What maintenance are you guys doing on these - just rotating every 50 hours? With the old massives used to media blast and re-gap then rotate, but these fine wires are a lot more delicate.
C180_guy offline
Re: Fine Wire Plug Cleaning?
I just take a piece of salty wire and clean out any lead balls (few if any) and put them on the pressure tester every 100-150 hours never rotate top to bottom.
DENNY
DENNY offline
DENNY
DENNY wrote:I just take a piece of salty wire and clean out any lead balls (few if any) and put them on the pressure tester every 100-150 hours never rotate top to bottom.
DENNY
Shhhhhh. Damn. You are not supposed to let anyone know about salty wire, I thought we had a deal. ;-)
I miss the days of Benzene. I remember pulling fouled plugs out of my 327 Chevy powered Jeep, dropping in a jar of Benzene, and watching all the gunk and carbon just melt away. And it's actually handy to be able to scratch my back with that third arm.
Barnstormer offline
I know we had a deal but both of us have one foot in the grave and the other on a banana peal so we gots to let it out for the young pilots!! :mrgreen:
DENNY offline
DENNY
Ok for us less learned, what is salty wire?
soaringhiggy offline
48 Stinson 108-3
Safety wire
I actually glass bead blast mine every year. One set is 18 years old and still going strong.
Aryana offline
Aircraft: 1955 Cessna 170
What brand of plugs did u ohm them. I have some champion fine wire not to many hours look good but most have over 5000 ohms. Just changed to tempest , they are all 2500 ohms
Cub180 offline
Aircraft: Cessna 180 skywagon, Supercub pa18
Always check resistance whenever plugs are out, below 5000 ohms are what you want. I have never had a Tempest fail but have seen many Champion’s fail, fine wire or massive electrode. Be careful cleaning finewire plugs. Consult the Tempest website for guidance.
DENNY offline
DENNY
9 postsPage 1 of 1
