Dog is my Copilot wrote:…. I am not sure exactly how much weight was saved since I did a lot of avionics work at the same time. ….. There is definitely a shift in CG but not as noticeable as I thought.....
A1Skinner wrote:Question on the Earth X batteries. Can you jump or boost them same as a regular battery?
So do you have to use this jump pack for the battery? Or can I use my NOCO one? Or can I just hook up battery cables to it? Same with trickle charging. Can i use my regular charger or do I need a special one from Earth X?nonrev wrote:A1Skinner wrote:Question on the Earth X batteries. Can you jump or boost them same as a regular battery?
https://www.youtube.com/watch?v=
https://www.youtube.com/watch?v=eTMdEe9 ... yA&index=5
chugachman wrote:.....Additionally, thoughts on Odyssey vs. EarthX? Sounds like you need a field approval for the EarthX - but woudl be curious to hear input on if there is an approved 337 out there for the EarthX, and why some might choose that over the Odyssey.....
hotrod180 wrote:chugachman wrote:.....Additionally, thoughts on Odyssey vs. EarthX? Sounds like you need a field approval for the EarthX - but woudl be curious to hear input on if there is an approved 337 out there for the EarthX, and why some might choose that over the Odyssey.....
Given all the hassle of getting an approval for an EarthX battery,
I'm curious as to what the advantage is of one of those vs an easily-approved Odyssey.
nickelb wrote:Here's my experience with the Firewall Battery - note Airplane is a 180H on Straight Aerocet Floats.
1. Great mod, felt awesome ripping out lots of weight + cables + Aux
2. CG felt fine with 2 bladed Seaplane prop and 470-R
3. When I changed to SPW Mount + PPONK + 3 Blade Hartzell CG is now too far forward I was hoping to compensate by removing vaccum and lightening avionics but no luck.
I've been experimenting with Water Bottles in the rear and survival kit to get the CG right, but it's a bit inconsistent as sometimes I have a passenger and sometimes not I will probably try a lead ballast in tailcone next.
I am looking into the new Hartzell composite prop as it is lighter, also interested in the MT 2 blade as it will probably shed even more weight but hopefully fix CG again.
185Midwest wrote:Hartzell expects to start test flying the Carbon fiber version of the Voyager prop in early 2021 from what I've been told.
MW
