I just got back from sloshkosh, 8th trip. It was very wet. Aircraft were not able to land and then could land, on and off for the first 3 days. There were aircraft stagged all over Wisconsin. 3000 landings a day. Left and right runways. I could have watched it all day. People cutting each other off, landing on the wrong runway and on the wrong dot. 3 dots on each runway and 3 aircraft touching down at the same time on each runway. They use up to 4 runways at a time not counting ultra light and rotary wing. Its just a stream of aircraft. There are a lot of pilots who are just not used to air traffic control and at Oshkosh you do not return a transmission unless it is an emergency. A lot of pilots do what they think they heard. Some aircraft can not keep up and aircraft are forbidden to s turn. Many arrive over gross on a hot day and come in slow.
I ended up flying in to Fond Du Lac because Atis said no more GA aircraft. The air traffic was intense and exciting. I think everyone should fly in once in their flying life. You will definitely be sitting on the edge of your seat.
