wingnut185 wrote:...... At 4k hours of mostly conventional gear aircraft I'm a relative novice at this flying thing, but somewhere between J3 and DC3 i got the general idea of how the controls work.
wingnut185 wrote:8GCBC wrote:Are you running out of rudder or lift? I am assuming the aileron(s) is/are hitting the stops? If so, need more airspeed?
Once again, I'm not looking for advice on how to land. I am looking for first hand experience with VG's on a Robertson 185. At 4k hours of mostly conventional gear aircraft I'm a relative novice at this flying thing, but somewhere between J3 and DC3 i got the general idea of how the controls work.
Barnstormer wrote:Roll rate has nothing to do with running out of aileron in a cross wind. If it's roll rate you are concerned about get a Pitts or give the rudder a good kick before you apply ailerons, will significantly increase the roll rate. If you are running out of aileron in crosswind land at a greater angle into the wind, your flying a RTOL 185 afterall, you can land super short. [emoji1] no offense meant, just funning
hotrod180 wrote:When the t/w is locked, there is somewhat less rudder travel than when it's unlocked.
wingnut185 wrote:thanks Rob, just might take you up on a ride.
