Oregon180 wrote:....in my experience the downsides tend to be exaggerated on the Internet.
Yes, but in my experience the up sides tend to be exaggerated also.
That's why I didn't say "good enough"--I said "if you're satisfied". But if they're easy enough to yank, then do so and make your own comparison for your airplane. If then you're not satisfied, screw them back on, or rivet them, or whatever it takes--heck, I'm not a mechanic.hotrod180 wrote:Cary wrote:.......Whether you would notice any measurable difference in your 180 if you yanked your flap gap seals, I can't say. But if you're satisfied with your airplane's performance now, why muck with it?
Because I can.
If "good enough" really was good enough, we'd still all be flying 65 horse Champs & Cubs-- and there'd be no 180's with the ponk 520, 185's with the 550, stol cuffs, VG's, or any other mods intended to improve performance..
182 STOL driver wrote:NO flap gap seals for me ! I wouldn't pay the mail / UPS charges to get any .KILLS 20% of your lift on takeoff -lengthens take off run . If Cessna thought they would make airplane faster or better they would have added them at factory .Aileron gap seals are different story -Have those to work with my SPORTSMAN STOL !
A1Skinner wrote:182 STOL driver wrote:NO flap gap seals for me ! I wouldn't pay the mail / UPS charges to get any .KILLS 20% of your lift on takeoff -lengthens take off run . If Cessna thought they would make airplane faster or better they would have added them at factory .Aileron gap seals are different story -Have those to work with my SPORTSMAN STOL !
Very interesting post. Where do you get the 20% figure from. In the post above yours we have a guy who repeatedly took them on and off for comparison and every time got better numbers with them on.
I enjoy these type of threads, seems to be one of the topics where engineering and real world don't line up very well.
182 STOL driver wrote:.... . If Cessna thought they would make airplane faster or better they would have added them at factory .Aileron gap seals are different story -Have those to work with my SPORTSMAN STOL !
hotrod180 wrote:182 STOL driver wrote:.... . If Cessna thought they would make airplane faster or better they would have added them at factory .Aileron gap seals are different story -Have those to work with my SPORTSMAN STOL !
The "if they were better, Cessna would have added them" argument could apply to aileron gap seals too.
182 STOL driver wrote:A1Skinner wrote:182 STOL driver wrote:NO flap gap seals for me ! I wouldn't pay the mail / UPS charges to get any .KILLS 20% of your lift on takeoff -lengthens take off run . If Cessna thought they would make airplane faster or better they would have added them at factory .Aileron gap seals are different story -Have those to work with my SPORTSMAN STOL !
Lower your CESSNA flaps and look at the end -looks like a Airfoil -now look at air flowing below wing at the area -it has to go over flap to produce LIFT. Best lift to drag ratio is at 17 degrees down( lower aileron at max and match) Wing on typical CESSNA 172-180-182 area is approx. 182 sq. ft. of which flaps is approx. 14% - of lift . If you have flap gap seal this amount of air or lift is going off the back with no lift.
182 STOL driver wrote:Lower your CESSNA flaps and look at the end -looks like a Airfoil -now look at air flowing below wing at the area -it has to go over flap to produce LIFT. Best lift to drag ratio is at 17 degrees down( lower aileron at max and match) Wing on typical CESSNA 172-180-182 area is approx. 182 sq. ft. of which flaps is approx. 14% - of lift . If you have flap gap seal this amount of air or lift is going off the back with no lift.
Terry wrote:If you fly your downwind at 80, base at 70, final at 60 and try to time your flare over the fence to hit the numbers and can live with floating in ground effect, flap gap seals are fine.
If you are into stabilized approaches with indicated airspeed below what your gauge will accurately read, using throttle to control your decent with little flare and no float, then I don't think you want flap gap seals.
But I have been drinking coors light and I'm due for another
mtv wrote:Terry wrote:If you fly your downwind at 80, base at 70, final at 60 and try to time your flare over the fence to hit the numbers and can live with floating in ground effect, flap gap seals are fine.
What he said! Except I don't drink Coors.......![]()
This is what it's about, NOT whether it'll take off shorter. If you fly the plane like the factory says, you'll never notice the difference. If you FLY the airplane like the STOL aircraft that it can be, you probably will.
And, Tim, Horton STOL kits are a waste of metal and labor to install. Install a Sportsman.
hotrod180 wrote:As a kid, I never liked letting others play with my toys, and as an adult I still fell the same way. Apparently he does too-- he never offered and I wouldn't ask. I have ridden in his 180 several times, and it comes right off the ground at least as well as mine and clips right along at cruise also. So I'd have to say that removing the FGP's didn't hurt performance any.
