Backcountry Pilot • Flew up to visit Zane + Maule heater effectiveness
21 postsPage 1 of 21, 2
Couple weeks ago I got to visit Zane's new playground. It was -18C, but we made the best of it with chili dogs.
Reason: Updated to reflect the real discussion here
rw2 offline
Aircraft: Experimental Maule
Re: Flew up to visit Zane
Right on, good to see planes getting used in the slow season. And thermometers being read in Celsius. :D
Ardent offline
Aircraft: A185F
Man, not even chili dogs could keep me warm in those conditions. You must have anti-freeze for blood.
Awesome stuff. Hard to believe there was slush under there with the temps that low. Snow blanket insulation works.
gdflys offline
Aircraft: Maule M-5-235C
Great video and I'm thinking Zane made the right decision to move to Minnesota. Even down here when riding my bicycle I have to deal with those snow mobiles that sound like supercharged bees.
The slush was mostly history by the following weekend after a week of super low temps. Either the surface had firmed up or the slush did. Either way it's not a factor currently. I went for a ski last weekend and it was crusty and hard.
Fun times and fun video. But….please tell me you didnt use a broom to clean off your windshield #-o . Looks like your heater wasn't putting out much heat since we could see your breath. I bet those chili dogs were yummy!
The broom made me wince too, but I presumed it’s a soft one used for nothing but airplane snow removal. And hey it’s his plane, his choice of removal. :D
Even then, I’ve been forced into the servitude of polishing too many windscreens at work on slow winter hangar days to remove micro scratches. I’m inordinately sensitive to window care.
Better to see it treated a tad too bush and actually flown than to see a pristine hangar queen treated to clean microfiber and silicone squeegees.
Ardent offline
Aircraft: A185F
Ardent wrote:The broom made me wince too, but I presumed it’s a soft one used for nothing but airplane snow removal. And hey it’s his plane, his choice of removal. :D
Yup, very soft brush and it's not like I was scrubbing. Just removing 97% of the snow so that the heater and the sun could sublimate the rest.
And *a thousand times yes* I believe in flying airplanes. If that means that the windshield has to be replaced every 8 years instead of 20, so be it. It's a pretty cheap thing to do. Like one AMU. So $100 or $150 per year for the ability to use the plane more. Honestly, I kind of wish I needed one now, since I need to pull things apart to replace the panel cover anyway. Really, the entire interior is due for a 20 year refresh, but you've seen the videos so you know this. :lol:
rw2 offline
G44 wrote:Looks like your heater wasn't putting out much heat since we could see your breath.
Maule heat is weak sauce. Love the plane. Love the people. But the heat is awful. Good thing I'm in the "dress for the crash" school anyway.
rw2 offline
Do you have the Aux heat/ heat cuffs on both exhausts? I can melt peanut butter on the floor in mine with temps below zero. We did exactly that on the way home from Alaska. Now the drafts up top are cold but the heat cranks. Seal up the drafts. It's worth it.
gdflys offline
gdflys wrote:Do you have the Aux heat/ heat cuffs on both exhausts? I can melt peanut butter on the floor in mine with temps below zero. We did exactly that on the way home from Alaska. Now the drafts up top are cold but the heat cranks. Seal up the drafts. It's worth it.
You have an M5? I have an M7. I've gotten a couple reports about the 5 having plenty of heat. But I'm still chasing a solution in the 7. I have the drafts somewhat under control with closed cell foam, and the floor vent puts out decent heat, but otherwise not much.
rw2 offline
Yes mine is an M-5. Do you have a heat outlet between the left set of rudder pedals and/or one under the right seat? The one on the pilot's feet definitely makes a huge difference. Keep the feet warm and all feels great. I was trying to check your heat controls in your videos but never saw a close up anywhere.
gdflys offline
Hear hear! Bravo, I’ve got a 185 I bought that isn’t shiny, and she’s for doing what you do. Getting out and seeing things and doing things. :D
Ardent offline
Aircraft: A185F
Had the same exact issue with a customer of mine. His 5 had great heat, went to the 7 and it was terrible. Even with the aux heater. He sold it.
Very interesting. Have any pictures of the baffling, heat muffs, scat tubing, slide valves etc for the 7? I wonder what changed. Any idea if it's an airflow issue or just blowing cold air not enough heat transfer in the muffs?
gdflys offline
Right muff heat comes from outside of right cylinder baffle through the muff and valve then goes to defrosters and under right front seat floor outlet. This one melted Peanut butter on the floor
Left tailpipe muff goes from left cylinder aft baffle back through muff then valve through firewall and right between pilot’s rudder pedals. Tons of flow and had the sole on a shoe actually come loose from the glue melting.
gdflys offline
Ah that was Zane! I just watched the video last night when I got home from a biz trip. Thanks Rich!
gdflys wrote:Right muff heat comes from outside of right cylinder baffle through the muff and valve then goes to defrosters and under right front seat floor outlet. This one melted Peanut butter on the floor
I'm curious if the added rear seat heat really takes away from the effectiveness 9f the heater in the M7. It is truly a rear seat heat as it comes up under the middle seat, so it doesn't warm them up, just warms the baggage area as very few that I know actually use that for a seat.
Great video! Love your content.
What did you have to do to warm up the motor? Did that blanket do enough?
HuskyCountry offline
Aircraft: Husky A1C/Cessna 400
