looks like fun.
GumpAir wrote:It's a non-event. You slide to a smooth stop.
aqua wrote:Yes, it has brakes. A thin rope tied to the floats trips a spring loaded brake pedal, that appears to be from a J-3.
As the dolly has no steering; the airplane is pointed to the right of centerline, to varying degrees. The 180 needs about 25 degrees. About the time p-factor brings you through centerline, the rudder becomes effective.
