EZFlap wrote:.
I said I would defer to high-timers, and two of them just spoke, so I will not challenge their 10X more experience than mine. Sincerely.
I may have not explained myself well... the point I was trying to make is that in addition to the well known Cessna forward CG problem (causing me to "run out of elevator" trying to flare with full flap deflection)... adding one more factor by making it so the airplane is descending much faster (due to slip/drag), means that it will probably require even more elevator authority to flare than I would have required at the "normal" full flap descent rate.
So the question I would humbly pose to the more experienced Cessna drivers is... :
Two identical 172's, solo pilot flying at forward CG, both with full 40 degree flaps, power-off, into a short strip.
+ One is descending at nominally 50 MPH wings level and coordinated, and one is descending at 50
MPH in a full rudder forward slip.
+ The vertical speed (rate of descent) on the slipping aircraft is (likely) showing 1.5 times the vertical speed of the non-slipping aircraft. So, arbitrarily, the non-slipper is descending at 800 feet a minute, and the slipper is descending at 1200 feet per minute.
+ At the bottom of the descent, it is required to abruptly and decisively arrest the rate of descent to prevent damaging the aircraft.
+ The pilot of the slipping aircraft can terminate the slip any time he wants, but the rate of descent for the next few seconds is still 1.5 times the rate of descent of the non-slipping aircraft (due to vertical inertia).
Which pilot will have more elevator authority to flare the airplane safely? Which airplane will make a harder landing?
EZ, IN my humble opinion, the guy in the slip will have way more authority than the other one, One mistake in your supposition is the 50 MPH forward speed with the guy flying the slip, his forward speed will be way less than the guy going straight.
When you turn the slipped aircraft back to heading you immediately slow your decent with up elavator as you come out, there is no seconds of more decent.
You are taking the non wing that was falling out of the sky(less forward speed) and transitioning to the full lift and drag of the full flap wing, you are also abruptly encountering Ground Effect, where flying it in with elevator all the way back you are wallowing through it.
You have the inertia of that gravity to allow you to flare where if your just driving in with the yolk all the way back, you already have it used up! (ELAVATOR) In the slip you will have lots of elevator left to use.
I think I said that right
Next go into a short strip with engine dead and no flaps? or full flaps, You want the least forward motion you can get! Your not worrying about getting the airplane out or off the ground again, your just worried about living through it?
It's actually just the opposite of rounding out for your flare??!!
Again I think I said that right??
