PA1195 wrote:There's no magic fix for the problem. You like some of the the rest of us learned enough to wonder how to deal with it and minimize the problem next time. Avoidance is an option but why not go beyond that step? There's lots of info on flying floats in below freezings temps if you search and as have you have done, ask. Some get an answer or options and are never heard from again. It can be discussed if you're willing to have a dialog.
Question: What were the air temps when you were flying or parked? Was that a clue? It's not been discussed so far.
Gary
steve wrote:I am sure someone will bring up the fact that rudder cable routing will vary from float to float, that can have some baring on the freezing problem. I don't have a solution, but understand your concerns, I can verify landing, then discovering you have no water rudders is a helpless feeling. Getting out on the floats in the middle of a lake, cold water, possibly windy, trying to balance yourself and free the cables at the same time is not a great experience. I carried de-icer for a while, but in the end the answer for me is to just leave the plane at home if having the water rudders freeze up is a concern. The risk of falling off a float in those conditions, or possibly banging up the plane trying to power boat it in to a tight area is not worth it for what in reality is probably a non-essential flight, that is my opinion, others will vary.
Steve
mtv wrote:There are a couple things you can try, but they have to be done BEFORE you’re in cruise.
One is, as you noted, cycle the water rudders up and down immediately after takeoff. That MAY work, but as noted above, depending on the installation, things may still freeze up.
Another approach is to simply take off with water rudders down, and leave them down. Problem there is water rudders are often rigged to compensate for float rigging, and when down in flight, they may induce unwanted yaw. Landing with rudders down once won’t hurt anything and the jarring on arrival MAY knock loose any ice. In any case, once on the water, you can push hard on the pedals, which will probably break loose any frozen cables. While cables may freeze, some force applied will generally cause them to slide through ice.
This solves the bigger issue, which is, with the rudders up, after landing there’s no way short of slithering (literally) back there to try to give one a kick to get it to extend. Best case, that gives you one water rudder, and very likely a polar plunge as well.
Don’t ask how I discovered that. Float decks in freezing conditions can be treacherous.
And, of course, by far the best program is to avoid this scenario in the first place, but sometimes it can sneak up on you.
hotrod180 wrote:Fraser Farmer, are you on straight floats?
Do you keep your airplane at Pitt Meadows?
I've been there (once) and know that the Fraser runs right alongside, and is used for seaplane ops, but don't know about access.
I assume there's a ramp, and maybe you have an alligator or trailer to tow the airplane to somewhere on the airport.
I've seen some imaginative home-built floatplane trailers at the Renton airport on Lake Washington near Seattle.
Karmutzen wrote:Sounds like you already have it figured out. Not uncommon on the coast with an arctic outflow, I’ve had elevator/rudder trims freeze up as well. Usually a bath in warmer water or even flying a couple feet over the ocean for a while was enough to thaw them. Gun Lake, you don’t have a lot of options except to get out and let the ball sit in the corner until you get home.
albravo wrote:Very interesting post.
My cabin is just east of Gun Lake, on Seton Lake and I was planning on flying in all winter. I started a thread a while back about floats in cold weather and Gary and Mike scared me enough that I'm using either chains or a sled to get into the cabin.
I wasn't scared about the water rudders freezing so much as control surfaces that may get splashed and frozen in place. Of course, water rudders that won't go down are one thing, but water rudders that freeze your rudder in place are quite another. I assume it would be a fairly thin coat of ice that would need to be broken but temps have to rise a lot before they would melt of their own accord.
Glad it worked as well as it did. It was a beauty day for flying.
mtv wrote:The physics associated with deep lakes freezing is pretty cool...pun intended.
As the surface of the lake cools, that water settles, to be replaced by warmer (relatively) water from below.
In a shallow lake, it doesn’t take long for the lake to “turn over” to the point where the surface is cool enough to actually freeze. Once that surface freezes, ice builds fairly fast, regardless of lake depth, as long as air temps stay cold.
But deep lakes have a huge mass of water, and it takes a long time of cold weather to turn over and freeze.
This is mostly a coastal phenom, because temps aren’t so severe as interior.
In Kodiak, we had a camp on an island in Karluk Lake, which is ~ 90 meters deep in places. Even in winters where the lake did freeze over, it took till middle January sometimes, and a few weeks later it would break up.....sometimes.
Of the 8 winters I lived there, Karluk only froze over three or four.
PA1195 wrote:I worked at five mentioned on Kodiak in 1970-71 and despite winter ice they were never warm enough to swim in summer. Intentionally...unless a hot sauna was close by.
Gary
