1954 170B 3400 TTAF
$80K
Avcon O-360-A1A 180 HP conversion 25 SMOH 1200 SNEW
Hartzell 76" constant speed prop Approximately 900 SNEW
Times are changing since we are having fun with it.
60A alternator
Engine driven vacuum system
EGT/CHT
VOLTS/AMMETER
Carb Temp
JPI FS-450 fuel flow wired to GPS
KMA-20 Audio panel
KX-170B NAV/COM
KI-201 indicator
KLX-135A GPS/COM wired to FS-450
KT-76A Transponder
Flightcom 403 4 place intercom
ACK ELT with remote
Avion center stack radio conversion
Glareshield with eyebrow lighting on rheostat
All interior surfaces primed that were disassembled for rebuild
RH landing/taxi light assembly installed
MaxPulse landing light controller
Grimes rotating beacon
Float kit structural parts installed
Battery relocated to aft of cabin
Flap trailing edge stiffeners installed
Lady legs main gear
Cleveland wheels/brakes
8.00x6 main wheel tires
ABI/Scott 3200 tailwheel assembly
Wingtip Strobes
BAS shoulder harnesses
BAS tail pull handles
Rosen visors
1/4" foam soundproofing throughout cabin
Airtex interior panels
Airtex headliner
Cessna secondary seat stop reel on pilots seat
10 degree flap comb installed
Fuel sump installed at fuel selector
Aircraft painted in original 1954 scheme, Flag Red on white
Cruises at 120+ KTAS on 9.5 GPH
Links to more pics, plus a bunch of pics of my jeep, the 185 pod I build, someone random ones from work...all because Flickr is smarter than an Airbus pilot
https://www.flickr.com/photos/75563491@N02/
It even flies!!!
http://youtu.be/f22mJ5PhLUs
Tony 720-220-8969
Al 303-888-2728
