Backcountry Pilot • FS: 1954 170B with 180HP $80K
13 posts • Page 1 of 1
1954 170B 3400 TTAF
$80K
Avcon O-360-A1A 180 HP conversion 25 SMOH 1200 SNEW
Hartzell 76" constant speed prop Approximately 900 SNEW
Times are changing since we are having fun with it.
60A alternator
Engine driven vacuum system
EGT/CHT
VOLTS/AMMETER
Carb Temp
JPI FS-450 fuel flow wired to GPS
KMA-20 Audio panel
KX-170B NAV/COM
KI-201 indicator
KLX-135A GPS/COM wired to FS-450
KT-76A Transponder
Flightcom 403 4 place intercom
ACK ELT with remote
Avion center stack radio conversion
Glareshield with eyebrow lighting on rheostat
All interior surfaces primed that were disassembled for rebuild
RH landing/taxi light assembly installed
MaxPulse landing light controller
Grimes rotating beacon
Float kit structural parts installed
Battery relocated to aft of cabin
Flap trailing edge stiffeners installed
Lady legs main gear
Cleveland wheels/brakes
8.00x6 main wheel tires
ABI/Scott 3200 tailwheel assembly
Wingtip Strobes
BAS shoulder harnesses
BAS tail pull handles
Rosen visors
1/4" foam soundproofing throughout cabin
Airtex interior panels
Airtex headliner
Cessna secondary seat stop reel on pilots seat
10 degree flap comb installed
Fuel sump installed at fuel selector
Aircraft painted in original 1954 scheme, Flag Red on white
Cruises at 120+ KTAS on 9.5 GPH
Links to more pics, plus a bunch of pics of my jeep, the 185 pod I build, someone random ones from work...all because Flickr is smarter than an Airbus pilot
https://www.flickr.com/photos/75563491@N02/
It even flies!!!
http://youtu.be/f22mJ5PhLUs
Tony 720-220-8969
Al 303-888-2728
AEROPOD offline
Re: FS: 1954 170B with 180HP $80K
Last week I was out at KFTG doing some miscellaneous work... The wind was howling, probably 20G30 and I look out of my hangar and see this beautiful 170 take off - I said to my son "no way he's coming back to land...". Sure enough I watched him do 5-6 T&G's in X-winds that I wouldn't have even taxied in!
On my way home I stopped at his hangar to see this bird - The workmanship is unbelievable!
Beautiful bird - I'd love own it!!!
Jim
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
As Jim said, the workmanship on this beauty is top notch. Tony and his Old Man have made this good plane an incredible plane.
Good luck on the sale, but I hope it doesn't sell too quick as I love seeing it around. :D
This photo says it all :shock: WOW!!! That is clean...
https://www.flickr.com/photos/75563491@ ... otostream/
Aryana offline
Aircraft: 1955 Cessna 170
Thanks for the kind words guys.
jaudette wrote:Last week I was out at KFTG doing some miscellaneous work... The wind was howling, probably 20G30 and I look out of my hangar and see this beautiful 170 take off - I said to my son "no way he's coming back to land...". Sure enough I watched him do 5-6 T&G's in X-winds that I wouldn't have even taxied in!
Jim
That's my dad...I've yet to meet anyone who flies a 185 like him. Thanks for mentioning this Jim, some folks think he's nuts, but it makes me proud to hear this stuff.
Matt, I forgot to give you credit for the video. Thanks again for sending it.
My dad emailed me today to tell me everything I forgot in the ad, so here's some more goodies it has:
Oil filter
Brackett air filter
Strapless windshield
Aileron gap seals
Heated pitot
Solid axles
Lndg lights in both wings
Hobbs meter
Ptt mike switches both yokes
Oil quick drain valve
Complete logs since new
AEROPOD offline
What is the empty weight?
What is the legal gross weight?
AEROPOD wrote:Thanks for the kind words guys.
Jim
Oil filter
Brackett air filter
Aileron gap seals
Heated pitot
Solid axles
Hobbs meter
I've honestly never seen anyone land a taildragger in those kind of winds and hit the numbers every time. I certainly would not have tried it in my Maule. I don't think you dad is crazy, I think he's got old school talent! I flew in about 20 minutes before in the Bo and remember the winds because it was the most x-wind I have landed in my new bird. The wind was 20G30 45 degrees off 26 (so... with a 08/26 and 17/35, there was no good option). It was all I could do to get around base to final with a lot of throttle to cut the corner, and I still undershot the turn.
Fun to watch and seeing that it was a pretty 170 made it better. My 10 year old asked me if I was a good enough pilot to do it... Nope.
jaudette offline
Vans RV-7a
Added a dozen pics of 46C in her natural environment.
AEROPOD offline
I like this one:
Zzz wrote:I like this one:
It's amazing what you can do with a cell phone and an ipad!
AEROPOD offline
Details...got these hubcaps done this week so had to get them installed. Added a few more pics to the flickr link too.
image by AEROPOD, on Flickr
AEROPOD offline
Whoa, those caps look great.
29singlespeed offline
29singlespeed wrote:Whoa, those caps look great.
The hub caps are for sale, $80k, but if you're a good negotiator, I may throw in an airplane
AEROPOD offline
