Backcountry Pilot • FS Cessna 182 Door & Trim **Sold**
Historical archive of past FS posts that have been satisfied or marked "SOLD," intended to provide reference for pricing and parts availability.
3 postsPage 1 of 1
**Sold**I have this 182 door, no hardware, and trim. Not exactly easy or cheap to ship, but if you come by Flagstaff you can pick it up, cheap $100. It is not damaged, just has duct tape residue all over it. Removed from sn 60851. If you just want the hinges, I will drill them off for a bit of coin.
dogpilot offline
Took ball and went home
Re: FS Cessna 182 Door & Trim
DP,
i might be interested. Seems one of my mechanics failed to close my 182B '59 door properly and when I returned in the afternoon; it was rather...compromised...in the lower forward corner.
By the looks of this unit it has the later door latch assembly which most likely will not be compatible/interchangeable but I bet someone here will have a better idea then myself.
Rocket
rocket offline
Hey Rocket.... if you want just the door... I will split it with you and take off the hinges...
You can PM me.
I live near Flagstaff. Nick
flightlogic offline
3 postsPage 1 of 1
