Backcountry Pilot • FS: Co Pilot Panel
FS: Co Pilot Panel
1 post • Page 1 of 1
FS: Co Pilot Panel
Cleaning out the hanger... Left over from my resto: v1.0 co-pilot panel. This was not perfect, so I made a second. I was trying to remember just what the heck I thought was wrong. I think it was the countersinks were not perfectly lined up for the MVP. (you can see where I egged out the holes to mount the MVP. Button heads would cover it up. Set up for an MVP-50, ELT switch, Hobbs, and txp/radio etc... Tight fit so the txp/radio needs to be mounted at a slight incline as to avoid the "Y" columb behind the panel. (cant really tell after install)
At any rate, if anyone can use it, it could use a home. Was fitted for a 66 H model, but should fit 180/182/185 etc... Sold as is as a dice-roll. $100 shipped.
Here's a pic of mine when I finished.
