Fuel leak
IF it’s is the bladder, and IF it is the RH tank, and IF you have long range tanks, and IF you want to risk the labor effort on installing a used bladder, I have one for sale. I know that is a lot of IFs.
I would make you a good deal on it. PM if all the ifs work.
PNW Flyer offline
245
- Aircraft: C182P
PNW Flyer offline
245
- Aircraft: C182P
90% of the time you just need to snug up the sender bolts. Simple cork gaskets. Open headliner a bit, careful with the teeth. Screw driver bit and ratchet wrench.
Mark Y. offline
440
- Aircraft: Cessna 182B
Sat Apr 23, 2022 10:36 am
lcdrles offline
32
- Aircraft: Cessna 180
Maule M5 180C
PNW Flyer wrote:IF it’s is the bladder, and IF it is the RH tank, and IF you have long range tanks, and IF you want to risk the labor effort on installing a used bladder, I have one for sale. I know that is a lot of IFs.
This thread is from 2018. He's probably got it fixed up by now.
Fraser Farmer offline
388
- Aircraft: 1977 Cessna 185
Fraser Farmer wrote:PNW Flyer wrote:IF it’s is the bladder, and IF it is the RH tank, and IF you have long range tanks, and IF you want to risk the labor effort on installing a used bladder, I have one for sale. I know that is a lot of IFs.
I hope so. I follow these troubleshooting threads and many of them you never hear the outcome
David K offline
142
- Aircraft: Cessna 172D
David K wrote:Fraser Farmer wrote:PNW Flyer wrote:IF it’s is the bladder, and IF it is the RH tank, and IF you have long range tanks, and IF you want to risk the labor effort on installing a used bladder, I have one for sale. I know that is a lot of IFs.
I hope so as well. I contacted Eagle Fuel Cells this morning to order bladders for the Bo’ and was told 10-15 weeks lead time. [emoji15]
cowpilot offline
125
'49 170A. (his)
'56 172. (hers)
