feedpro wrote:"running a tank dry" did me in.
Interesting, we have had this same discussion on a Beechlist. What was the general feeling on this?
feedpro wrote:I am an old, long time pilot
Bonanza Man wrote:The other 5% are horrified.
Zane wrote:I'm a young(er) short time pilot, and I'll admit it horrifies me. Not running one tank dry so much as using that method for a estimate of fuel endurance. Do you guys dip your tanks? Or just fill up and go?
Bonanza Man wrote:
Can't dip tanks in the Bo. I can have 20 gallons in each of my 40 gallon tanks and never see a drop due to the shape of the tank and wing dihedral. Unlike in the 182 where you could measure even 5 gallons. I made my own dipstick for the 182 but not for the Bo. I have a tab sticking down that shows 30 and 35 gallons. Ido have a fuel flow from Electronics Int'l and it works very well. It was .3 gallons off over about 50 gallons, never bothered to adjust it.
ccurrie wrote:The thing I have always wondered my 170B is plackcarded to use bolth tanks for takeoff and landing wich is kind of pointless if one tank has been run dry.
ccurrie wrote:The thing I have always wondered my 170B is plackcarded to use bolth tanks for takeoff and landing wich is kind of pointless if one tank has been run dry. I presume this is so you have max fuel flow in case of an overshoot but like MTV I would rather have 5gal in one tank than 2.5 in each. What do you 170-172 guys do in this situation?
I went out on a hot day and did simulated go arounds at a safe altitude on each tank with the boost pump on and off and couldent make it hickup so I dont worry about it too much but I still wonder somtimes.
