Fuel options for straight float Cross Country; ME-MN
Wed Aug 13, 2025 10:35 am
Asking the brain trust to see what there are for fuel options (seaplane bases or airports by water) for a cross country from Maine to Minnesota? The standard route would send me through Canada and while I'm not opposed I would like to see what options there are along the route staying in the US. Thanks in Advance!
mainebushpilot offline
6
- Aircraft: DHC-2 Beaver, Cessna 180D Skywagon, & PA-18 Super Cub
Fri Aug 15, 2025 10:29 am
Also curious. What's the standard route? And what's your airplane and it's range?
1977
- Aircraft: 1955 Cessna 180
If you're an SPA member, look at their Seaplane Base data. I doubt that routing would be that difficult, but I'm betting Canada would be shorter/easier.
10588
Several NY float guys here, maybe be they’ll chime in.
3000
- Aircraft: None
As a SPA member for several years now, and I have to admit using their tools to plan a cross country leads me to believe they are pretty clueless about how to build tools to support planning such endeavors.
1977
mainebushpilot wrote:Asking the brain trust to see what there are for fuel options (seaplane bases or airports by water) for a cross country from Maine to Minnesota? The standard route would send me through Canada and while I'm not opposed I would like to see what options there are along the route staying in the US. Thanks in Advance!
Fuel available in Kingston, NY. RON is also available at our dock. DM for specifics.
TR
TR offline
167
- Aircraft: PA-18A
C-180H
DHC-2
G-164 Ag Cat
soyAnarchisto wrote:Also curious. What's the standard route? And what's your airplane and it's range?
Shortest route is straight across through Canada. Planning on keeping it in the US for this flight since it'll be my first long flight with the plane (C180). As far as range and such I'm still working on the numbers form previous flights I had done with the plane to gauge that.
6
I played around with airportpicker.com and found some seaplane bases that might work. Caveat... I'm just sitting at home on my couch. I haven't flown to any of these. Phone calls would be prudent. I just put in a route from MSP to TOL to BGR, checked the box that said "isolate water" and selected "search 30 mile radius"......
KMSP 11C 2C9 E75 K03 KBGR
There seems to be a cluster of seaplane bases about 30 north of Ft. Wayne.... C67, IN2, 7J4, O1E, I58, .... there must be some seaplane activity in that area.
kg offline
483
- Aircraft: Cessna 180J
There aren’t many seaplane bases once you leave Maine.
Helm’s in Long Lake, NY. NY9
Better check ahead, I heard they’re pulling the fuel tank late summer
Paynes Seaplanes Seventh Lake, NY
I can help near Penn Yan, NY KPEO,
if I’m around
Moving west, I have list of marinas in PA and MI if you can use auto fuel. LMK
aqua offline
240
I will be driving through Long Lake Thursday, I will see if they still have fuel. Their blue 206 was there a few weeks ago when I flew over.
Pete
pburns offline
509
- Aircraft: Citabria 7ECA
It didn’t look like there was a fuel tank at Helm’s in Long Lake. I didn’t stop, since I was towing a canoe trailer, but am pretty sure it’s not there. I might be flying that direction later today , if so I’ll take a look from the air.
Pete
pburns offline
509
