courierguy wrote:The above unporting issues, and how they relate to which tank, both or single, is selected, is why I went with a header tank on my experimental. Any "drama" up at the mains is settled down by the time the fuel flows out the bottom of the 3 gallon header tank.
On this whole fuel issue, since I have not been to Oshkosh since 1988 (lots of reasons why, didn't miss it for one) and I have relatives back east, I am starting to ponder going this year. IF I do, I will make the entire flight there and back on mo gas. Now that's no big deal, as the suitability of mo gas, even E-10 mo gas, and the Rotax is a no brainer, everyone I know that flies with a Rotax uses mogas, though many draw the line at E-10. But when they go XC, they revert to buying av gas, but I have the means to get my own mo gas, using my electric bike, trailer, and fuel bladders. Anyone know of others making the trip all on mo gas? Sure, it can be a PITA, if you're in a hurry, I won't be, or I won't go. It will for sure add to the challenge, and in fact that challenge is the main reason I would make the trip. There, I said it, now the pressure is on to do it! On the other hand, I have not worn out Wyoming, Utah, Montana, or my home state of Idaho yet, I still am not bored flying "local," so it's hard to go elsewhere.
Karmutzen wrote:Blowing a tank dry was SOP flying Beavers, always done at cruise. Some had a low pressure light that would come on that would give you 10 seconds to switch tanks before the engine quit. You used every drop you had and didn't want to run one dry at a bad time landing or taking off. Same concept others are using here on other airplanes.
mtv wrote:Running a tank dry, you know exactly how much gas is left in that tank, and you're not going back there.
Hammer wrote:I understand running one tank dry as a way of compensating for inaccurate fuel gages, but with a fuel flow meter telling you exactly how much gas you have, I don't see any point in the practice. If anything, I think you're exacerbating the chances of "running out of fuel with gas on board".
While not particularly likely or common, there are numerous things that can go wrong while switching tanks which won't go wrong flying on Both. Both the fuel valve and the linkage to the selector handle are moving parts and not immune to failure. So if switching tanks doesn't buy you anything of actual value, it's a poor practice... especially over unforgiving terrain.
As far as unporting the fuel line...I get the theory, but in practice I've never had an engine sputter and catch, turbulent air or not. When a tank runs dry the engine just stops. I don't believe you get ten seconds more power by running one tank dry then switching to the other tank.
I could be wrong of course, but that's my experience.
Hammer wrote:colopilot wrote:glacier wrote:...
If you fly on Both tanks and see that one fuel gage isn't moving, that's a pretty good indication that you don't have access to that fuel, maybe because of ice or some other blockage.
Or you're just in a Cessna with their magic vents. Due to cross-tank vent placement and wing dihedral, they have a tendency to suck the fuel from one tank to the other as it's consumed for a good while, until you finally get the fuel level low enough in the feeder side to break the suction. You still have all of the fuel available in flight, you just effectively draw most of it from one side as it transfers from the other. Other than alternating tanks or flying cockeyed, there's also not much you can really do about it. The newer models have an updated design that greatly lessens this phenomenon.
Interesting...I've never flown a Cessna that does that, though I don't doubt some do. Maybe Monarch caps help?
First was C185 on floats picking up load of hunters made a left step turn take off in a marginal lake with fuel tank on right tank
just cleared shore line and engine quit 30 feet.
Landed safe
Gauges got fixed 2 days later
mtv wrote:.... Even suggesting that an off airport forced landing due to fuel exhaustion is a viable option is a fool's game.
contactflying wrote:I agree with Hotrod180 that forced landing in a light airplane is a dumb way to die. Except at night or over cold water, it should result in an embarrassing incident. If it doesn't, in my opinion, something bad happened in the last six seconds to cause the pilot to quit flying and do something else. From 200' down is six seconds. For those who fly low, engine failure emergency procedure is: maneuver to a landing site and land. Doing anything else could be fatal.
I really think flying low all my life was a big advantage. I never had to make the decision when to stop trying to restart and concentrate just on landing.
Hammer wrote:... there is a LOT of terrain in the backcountry where I just don't believe that is true. I always play the "where you going to land" game when I fly, and it's not uncommon to go 30 minutes without a single option that doesn't guarantee complete destruction of the aircraft and "who knows" for the people inside.....
