Hello all,
Thought I'd tap into the wealth of knowledge out here and see if anyone else has had difficulties with their older model Garmin dashmount GNC 250 XL Nav/Comm. The trouble I'm having is the unit will fire up, accept the data inputs and display the navigation information, then for no reason, shuts down then instantly fires back up and goes through the self test process. This becomes a real PITA when setting up for any cross country flying.
So is this an isolated issue or are there others out there that are or have had this kind of trouble. I know the easy fix is to replace it with a newer model with all the bells and whistles, however I'd like to hold off and spend the money on fuel instead. Any feed back would be much appreciated. Thanks....
