Backcountry Pilot • GI275 and flap indicators
6 posts • Page 1 of 1
I was in the sim today and it got me thinking about flap indications
On our airspeed tape at work it will show basically the max and min speeds for each flap range
Now this isn’t a need but a want
Is there a way for a Gi275 to redisplay speeds based on current flap setting, say min and max speed for each flap setting?
Or do something similar?
Figured if I’m going to be adding the 275s be cool to have them “be all they can be”
Thanks
Re: GI275 and flap indicators
You mean top and bottom of the white arc?
Or do you have approach flaps available in your place at a higher speed?
GI 275 installation manual page 5.5.1.1
redacted offline
Aircraft: Cessna 170
redacted wrote:You mean top and bottom of the white arc?
Wondering if it can give me a max and min speed per flap setting if I put in a micro switch or something
Basically so when I have flaps selected it would reset my barber pole for max flap extended and mark my min flap speed too
Not sure if you can move the barber pole to the top of the white arc when you extend flaps but......it's also literally the white arc. Read the manual, there's some customization availabe but also everything has to be in accordance with the aircraft TCDS.
redacted offline
Are these RSTOL numbers?
frstnflt offline
Aircraft: Cessna 185
Indeed
