Backcountry Pilot • GOPRO choices
GOPRO choices
26 postsPage 2 of 21, 2
Re: GOPRO choices
rw2 wrote:
svanarts wrote:How does the gopro handle "prop effect?"
It doesn't. All CMOS sensors (which is all action cams) have this problem.
Here's one work around: http://www.eyeofmineactioncameras.com/G ... esnp-3.htm
This reduces the light hitting the camera and forces a longer shutter speed, reducing or eliminating the problem.
Is this the same type of filter that Sporty's is selling for less money or does the sporty's filter have anything better?
Superdan00 offline
FindMeSpot URL: https://share.delorme.com/DanielKeller#
Aircraft: Found Aircraft Company Bushhawk FBA-2C2
Aviat Husky A1C-200
Columbia 400
Found FBA-2c2
Bush Hawk XP
Bushhawk
Re: GOPRO choices
Superdan00 wrote:Is this the same type of filter that Sporty's is selling for less money or does the sporty's filter have anything better?
No. The sporty's one is a neutral density filter. This is a polarized filter. They are different, but *might* achieve the same goal in this case.
rw2 offline
Aircraft: Experimental Maule
Re: GOPRO choices
This is polarizer only:
http://www.youtube.com/watch?v=A-KPuaaZlDE
But your mileage may vary with different polarizers, some may be more stopped down than others.
I experimented with adding a neutral density filter in addition to the polarizer, and it became sensitive to vibration blurring, meaning the scan rate was too slow to capture good sharp definition if the engine was at a more vibrational RPM.
Re: GOPRO choices
Zzz wrote:This is polarizer only
How was the color? Did you have to correct? I'm helping a new friend from the Lone Star fly-in and his video is so muddy that it's basically useless. There simply wasn't enough data left to do a good color correction, it was all compression artifacts.
rw2 offline
Re: GOPRO choices
Zzz wrote:This is polarizer only:
Nice video. Like the perspective. Is that electric trim on the top of the stick?
Crzyivan13 offline
Aircraft: 1957 Cessna 182A
Re: GOPRO choices
Have a Hero 3 Black edition.
Use it mounted inside on a frame tube and outside on strut.
Use both hand-held remote and iPhone and iPad for remote activation. Find that the hand-held remote allows longer camera battery life. Getting about 1hr 15min video time.
The filter is a must and you can contact the guys @ nFlightCam for mounting options and hardware
which are simple and usable in multiple places.
GoPro customer service was excellent about helping with set up of camera and instruction on using App for iPhone and iPad. Reminder: Camera will not charge from your computer...even though the light is on. GoPro suggests to only use "small block" or 1amp charging. (Using "big block" charger, for iPads, can significantly affect battery in the long run...)
------- "If we are not meant to have midnight snacks, why is there a light in the fridge?"
MS Pirate offline
