Backcountry Pilot • GoPro Suction Mount
GoPro Suction Mount
Discuss cameras, lenses, techniques for shooting and post-processing. Please do not ask questions about how to post photos in the forum. See the Help section for website usage questions.
27 posts • Page 2 of 2 • 1, 2
Re: GoPro Suction Mount
The other problem with tethers is that you lose the chance for some truly epic footage...
rw2 offline
Aircraft: Experimental Maule
rw2 wrote:The other problem with tethers is that you lose the chance for some truly epic footage...
And this is what happens when you shoot at 30FPS, Jello and frame tearing. Now if he'd shot at 120FPS he could have slowed down the footage for something truly epic...... I'm also glad the camera didn't have to pass through the pigs digestive tract before recovery....
IrishmanPDX offline
IrishmanPDX wrote:I would love to see what people are using for mounting options and angles, anyone want to share some photo's or sketches? Believe it or not, I've found that even doing a previs animation in Powerpoint can be very helpful.
Options will largely depend on your airplane. Strut mounts are universal on almost any high wing and let you get some neat angles. I do have a tie-down mount intending to get some shots from the tail ring forward or aft, but haven't messed with that much. But I am not super wild about the potential to torque in the wind, so I might rig up something better that will brace against the empennage.
I'm still working out a vertical fin camera mount, and am deciding if I want to use a side-mounted hard mount, or design something myself so that I can center it on the fin (reduced drag and no side load on an important part).
One thing I haven't decided on yet are any sort of anti-vibration mounts like VibeX or the like. I want to upgrade to the Hero 7's, and the vibration reduction technology in those is reported to be amazing. I want to try it out first before investing in gel mounts. Any other camera and the mounts would be a given to reduce airframe shake.
colopilot offline
Aircraft: 57 182A
And yet another failure...
Henny offline
Aircraft: Cessna 185C Skywagon,
de Havilland DHC-2 Beaver
Great stuff Henny....
SquareHead offline
Aircraft: C170B/Super
This footage and quite a bit more from this trip was filmed using a Gopro suction mount.
The key is to find the stiffest spot (usually in a corner where a rib and spar meet) for mounting. Don't recall if I ever took it up to 150 IAS, but it worked well for most of the flying we did.
If it is mounted to free skin, it will stick pretty well, but vibrate a lot.
Scolopax offline
Hey there, I'd be interested in that mount. Drop me an email at: [email protected]
Thanks, Chris
Hawkeyenfo offline
Aircraft: 1941 PT-13D Stearman
1952 Cessna 170B
1960 Piper Aztec
1948 Stinson 108-3 project
