Rob wrote:..... I ended up using Steve Knopp himself, and couldn't have been more pleased with the engine or the transaction. Only 3 hours so far, but smoooth and beastly....
Glidergeek wrote:
...His package was 24K including the STC (he's Pponk authorized) Included mags, vac pump, oil cooler, Plane Power alternator conversion, converted my old oil pump to a new style. Be careful if you got an R crank it'll have to be changed make sure that's in ur " ". R's only have 2 counter weights on them and for a 3 blade they require a 4 wt crank.
180Marty wrote:The crank for an O470 K and L have 2 sets of counterweights so I'm pretty sure will work.
flynengr wrote:What is the cost for the crank replacement? I'm guessing this upgrade is for all non-"U" model O470's? Or is it just for R's? His website also indicates his STC is only for H model 182's through R's.....Anyone doing field approvals on the earlier models? Seems strange that the STC would be good for all 180's, but not the 1959 182B. I understood that the 182B and 180 in 1959 were as close in design of any.
Looking at a 182B with an engine past TBO and just trying to run some numbers....
Thanks,
Flynengr
qmdv wrote:Talked to Steve about my 182B and he said that a field aproval was no sweat.
So he found a NEW O-470U crank HE bought it for $5200 and got $1500 for mine he absorbed the loss.
Glidergeek wrote:Last I heard airport is still closed, don't know where the water is. Bunch a planes on the east end of the airport and some on a vacant lot off of Maple outside of the airport. I'll cruse by sometime this weekend and see.
