whee wrote:What GRT unit do you have Blackrock? How bout a whole panel shot. [emoji3]
blackrock wrote:Whee,
I know what you mean about panel space and I've thought about relocating my EIS, too. I haven't done that for a couple of reasons.
1) It needs to be accessible to enter fuel on board; at every fill up I update the amount. Also, having a metered fuel management system is a huge safety benefit, IMHO. I would recommend the EIS be visible solely for this purpose,
2) I use it a lot. There is so much information quickly available on it, that I go to it often, although you can get the same info from the EFIS,
3) When the big red warning light on the panel starts flashing, a quick glance at the EIS will tell you immediately whats wrong, and
4) It is the alternate air speed and altimeter so I want it visible in case I ever have to use it as a legal backup. ( I don't need back-ups to safely fly the plane in VMC, however).
I suppose it could be mounted somewhere else like a wing root, but really, it is used as a primary instrument in my panel. If I were flying IFR, I'd have dual independent EFIS's and AHRS's, (GRT Horizons, not Sports) with back-up battery power for all, but that's just me.
whee wrote:
Great points but I have a couple questions. Sorry I've been bugging you so much lately Blackrock.
You can't enter fuel on board from the EFIS? If not then yeah, the EIS needs to be readily available.
When looking at the EFIS specs I didn't see any features of the Horizon I really wanted or felt like I would miss for flight in IMC...but since I have no instrument rating I don't know what I don't know. With the Sport with SV and the Mini-X I'll have dual independent AHRS and GPS systems each running on separate batteries. That seems pretty good to me. What am I missing?
