Skylane wrote:Well Bob and Rob, if you two start PMing include me in there because I'm kind of in the same situation.
Thanks, Bub
I believe it's perfectly legal to use a PORTABLE medical oxygen set-up in a private aircraft. FBO's may not refill them, but you don't want to pay their fees anyway. I have used any set-up that will give the needed O2 for 40 years, and just refilled at the local welding supply. DO NOT EVER TELL ANYONE WHAT YOU ARE REALLY USING THIS BOTTLE FOR!!!!!!
This has been beat to death on various soaring forums and the bottom line is that ALL commercial oxygen is created equal.....if you don't plan to go to the edge of space don't worry about it. The truth is that you are less likely to die from contaminated oxygen in your airplane than in a hospital!
Cheers,
Rocky
