JP256 wrote:Contact, I have learned a lot from your book, and from your many posts here on BCP. But I have to admit that the whole "proactive control movement" to "bracket the runway" leaves me stone cold. It strikes me as aerodynamically inefficient, and has to be inherently destabilizing. Taken literally, and taken far enough in practice, it seems like it could be the final aerodynamic straw that initiates a ground loop, just as in a helicopter, rapid proactive movement of the cyclic can be the final aerodynamic straw that leads to dynamic rollover during a slope landing. And while I recognize there are many differences between flying helicopters and flying fixed-wing aircraft, the laws of physics still apply to both.
When I was instructing in helicopters, many of my students over-controlled both the cyclic stick and the anti-torque pedals – often extensively. We could not move on to tactical training with (which involved slope landings on unprepared surfaces) until this "over-controlling" tendency was eradicated. Those tendencies were only magnified when flying with Night Vision Goggles, which also raised the bar for difficulty on slope landings. I couldn't pass them as "mission qualified" until they could accomplish all the basic maneuvers during day, night, and NVG flight.
Because this was so difficult a habit to break, I used to demonstrate the inefficiency of this "proactive control movement" technique by establishing a stabilized 1-foot hover, then "walking" the anti-torque pedals back and forth like the student was doing. Every time (100%) the aircraft would settle and touch down, remaining on the ground (though "writhing" slightly) while the "proactive" pedal movement was continued. But as soon as we stopped walking the pedals back-and-forth, the aircraft would lift back off and return to a stabilized 1-foot hover.
Then I would repeat the demonstration, but this time "rowing" the cyclic stick quickly back and forth, forward and back. Again, every time (100%) the aircraft would settle to the ground (though generally this technique resulted in a somewhat "bumpier" touchdown). And again, as soon as we stopped "proactively" moving the controls, the aircraft would lift back off and reestablish the 1-foot hover.
I would then demonstrate to them that an entire takeoff, traffic pattern, and landing could be done without moving the cyclic stick more than an inch in any direction. I would establish a standard 3-foot hover, have them make a circle around the cyclic stick with their two hands, and fly the entire pattern without touching their hands with the cyclic. Had I been less scrupulous, I would have placed wagers with them, because to a man, they believed it would be impossible. Yet within a couple of hours, they were duplicating the feat themselves! For students who had been literally beating my legs with the cyclic stick, it was an eye-opener, for sure!
Jim, I know you flew helicopters as well, and I suspect you're very familiar with what I described above. It just seems to me that in much the same way, "wagging" the tail on landing (proactive rudder movement) is aerodynamically inefficient because you're constantly creating "upsets" that have to be cancelled by the counter-movement. That is simply inefficient, and means that some portion of the control input is completely wasted. Thus you have less true "reserve" control, because you've wasted some of it countering the "dynamic" disturbance – which you just created.
The same aerodynamic inefficiency would occur from "rocking the wings" (proactive aileron movement) or from creating "pilot induced oscillations" (proactive elevator movement). It just makes zero sense to me to give up aerodynamic efficiency in all three axis while simultaneously demanding more and more control movement to return the aircraft to a "neutral" (stabilized) condition.
Is it harder to train pilots to be able to make "reactive" control movements? To recognize the smallest change in sight picture and react quickly enough to apply control pressures to counter those movements? I will grant that those statements are probably true. But I would also postulate that just as new helicopter pilots at some point "find the hover button", new tailwheel pilots will find the "centerline" button as well. But not if they are taught that it is "correct" to constantly over-control the rudder, ailerons, and elevator through "proactive movement". Those pilots will always be "out of control" except for the brief micro-seconds when their controls pass through the "neutral" position for their particular aerodynamic situation.
Jim, I respect your experience and background immensely, and I truly mean no disrespect. I will readily acknowledge that my experience is minuscule compared to yours. I truly would like to hear your thoughts on the above, and how you reconcile your "dynamic proactive control movement" philosophy with all of this. Thanks!
contactflying wrote:Jim,
Thanks for your support elsewhere and for your and MTV'S criticism of dynamic proactive rudder and elevator control movement. You, MTV, Cary, and others here are better instructors than I am. You have accomplished the mission and helped many through the program. I have always been a pain in the neck and as Richard Castle, who wrote the forward to "Contact Flying," said to me, "Jim, you are a renegade. You have always been off the reservation."
What I have done, both military and civilian, is pick up on good technique both from others and from experience. You are right about the laws of physics. Not just helicopters, but many machines have similar characteristics. There are also similar interface with human aspects. Dynamic proactive control is one of those.
While there are similarities between anti-torque longitudinal axis alignment and rudder longitudinal axis alignment, there is an important difference. The helicopter is powered up fully before any control input. The tw airplane needs gross rudder movement when airspeed is slow and finer rudder movement when fast. In either case gross or fine anti-torque or control movement will work. Efficiency, no. And while helicopters will demand full attention throughout all operations, airplanes can put a pilot to sleep; especially his feet.
You are right about slope operations. Finding the ground loop tip point in a Cub can be embarrassing and damage equipment. Tipping the tip path plane can be fatal. Parts generally fly outward, but can get inside the helicopter as well.
Exaggeration is not a popular instructional technique, but it works. If a student finds out that gross control movement, say rudder to the stops dynamically and proactively during slow taxi, works, he will not fear bad things happen and fear others are watching. Dynamic proactive rudder movement needs to be finer, for efficiency, when fast on takeoff, but gross will work. The beauty of dynamic proactive control movement, both rudder and elevator, is that the student needn't fear too much or too little. It allows for a great deal more discovery learning. It allows the student to gain experience and confidence quickly.
Yes, the book supports static reactive control movement. Theoretically, it is more efficient. I preach efficiency on takeoff, but I will sacrifice some to stay ahead of the airplane and not wait until it decides to err. On landing, 40 degree flaps, slats, dirtiness, or any other type of inefficiency is actually desirable. The design of the airplane is to fly, and here is one place we don't want that.
People are going to do what they do, especially old ones. As instructors, we have to really think hard about our orientation and how we pass that orientation on. Do we want their feet to move? Do we want them to wait and react. Both work and the later is theoretically more efficient. What is the advantage of always being ahead of the airplane. What is the advantage of putting the longitudinal axis, between our legs, just a bit left of centerline followed immediately by just a bit right of centerline, etc. continuously?
My students don't believe an airplane will necessarily climb and let the nose go down a bit in a turn. In the pattern. Is that safe?
Think about what you teach in terms of perpetual student (later pilot) orientation.
akschu wrote: My favorite ground loop video: ....Pilot basically just quits flying....
hotrod180 wrote:akschu wrote: My favorite ground loop video: ....Pilot basically just quits flying....
Here's a video of a Lockheed model 12 groundlooping in Belgium.
A guy I know hel;ped fly it over to Europe not long before this incident.
The fun (not) starts at about 1:40.
https://www.documentingreality.com/foru ... ng-187922/
mtv wrote:JP256 wrote:Contact, I have learned a lot from your book, and from your many posts here on BCP. But I have to admit that the whole "proactive control movement" to "bracket the runway" leaves me stone cold. It strikes me as aerodynamically inefficient, and has to be inherently destabilizing. Taken literally, and taken far enough in practice, it seems like it could be the final aerodynamic straw that initiates a ground loop, just as in a helicopter, rapid proactive movement of the cyclic can be the final aerodynamic straw that leads to dynamic rollover during a slope landing. And while I recognize there are many differences between flying helicopters and flying fixed-wing aircraft, the laws of physics still apply to both.
Very well said. I couldn't agree more.
