WWhunter wrote:I think a hand held radio should be easy to use, ergonomic, intuitive, have good power, easy to get battery power, have standard antenna connectors (Yaesu does not)
Yaesu FTA-550 has standard BNC antenna connector.
a3holerman wrote:
The problem with Icom and Yeasu and the others is that they have no idea what is really needed in a aviation handheld. They are all versions of their Ham/commercial radios and are not at all tailored to aviation use. Can I say here that it really pisses me off.
Re: Hand held radio...which one? Part II
Wow. A lot of good information has been put up. I've added a few images down below.
I am beginning to lean towards the Yaesu FTA550A which uses a regular NiMH or Alkaline AA cell (x6) battery back, although you can retrofit a lithium battery later as well if that floats your boat.
* Yaesu FTA550A has a larger screen ( 1.7” x 1.7”) than either the Sporty’s SP400 (1.63” x 1.63”) or the Icom A6 (?” x ?”; it looks smaller when compared side by side)
* The Yaesu has a removable BNC connector rubber ducky antenna that can be removed to run coax to a dash or window mount antenna. Same for Sporty’s SP400 and Icom A6.
* Yaesu FTA 550A buttons are large and comparable to those on the Icom A6. Sporty’s SP400 are maybe a bit better.
* Yaesu FTA550A offers a speaker mic option, either a Yaesu OEM unit ( for about $60) or a cheaper compatible speaker mic by Pryme (< 30 dollars). Sporty’s SP400 lacks a speaker option. Icom A6 also offers a speaker mic.
* Yaesu FTA550A offer use of the battery cell pack or one can later buy the lithium pack, but that’s not my choice; I prefer using simple always available AA Cells.
* Price: The Yaesu FTA550A can be had for $ 189 brand new from some of the internet pilot supply sources. The Icom and Sporty's units are a wee bit more..
Years ago I wrote to PS Engineering about this, and the president/owner of the company I believe is also a ham radio operator. Anyway, I am a tad fuzzy on the exact details, but I am not sure whether an amplifier, home-brewed or otherwise, in this frequency range is permitted unless it is FCC approved. Issues with spurious radiation, birdies on certain harmonics, bleed over, signal bandwidth, etc . can be a concern. Being an AM signal with a central carrier, there are lots of issues to look out for..
. Zenithguy wrote:
I purchased a linear amp and it boosted the output to 10 watts, which is the same I believe as a panel mount radio. Worked great.
) , you can even try to match your FCC assigned ham radio call letters to your FAA assigned aircraft tail number. You have to first earn the highest level Extra Class ham radio license to qualify to apply for a short four digit call sign such as N-(#)-(Letter)-(Letter). Then you have to be lucky and reserve a short matching tail number N-(#)-(Letter) -(Letter). Not all ham radio calls start with an N by the way. Other starting letters include K, W, and A. You can also talk on a ham radio on lots of other non VHF frequencies and operate what they call aeronautical mobile. Here is a picture that is so beyond cool it makes me cry.
