Backcountry Pilot • Hangar Flying
Hangar Flying
27 postsPage 2 of 21, 2
Re: Hangar Flying
BBQ freezer f
tcraft offline
shawn coleman
2202T
tcraft f-22
Re: Hangar Flying
I hate to bring it up, but depending on your airport the local fire marshal will likely be paying you a visit at some point. So figure out just what the limits of contents are from the fire protection point of view. Wiring for better lighting is often a problem. Some places are easy and others are terrible. It is best to know the rules to play the game. Therefore, a fire extinguisher or two.
mike b offline
Aircraft: Navy N3N & Carbon Cub
Re: Hangar Flying
gbflyer wrote:Need girlie calendars. :-)
Especially the ones from Snap-On and NAPA. Don't forget a dart board, too.
Alan Image
ViperPilot offline
Re: Hangar Flying
For me, other than my aircraft, what I value the most is hundreds of photographs that represent the most memorable moments in my 40 years of flying. Even if I lose my airplanes, I would still sit in there and relive those precious moments!
PatínLoco offline
Re: Hangar Flying
BBQ - Yes. I need to replace the one I have to set fire to with a propane unit.
Fire Extinguishers - I fortunately inherited a healthy pile of them. I'd like to hang them in various places instead of having them sit in a pile.
Electricity - Yeah, I'll be taking a generator down. The breaker is locked in another hangar.
Photos of Memories - Yes. I need to make those memories though. Just getting started.
Great additions, guys.
-Glen
jet966 offline
Re: Hangar Flying
Same here, lot's of pictures, some that will never see the light of day or at least be seen on the internet. When Greg Swingle was shooting video while in my hangar I had to caution him on that, some embarrassing, some that other's may think were just "wrong" for various reasons. :twisted:
That brings up the need for a easy way to mount the pictures, and though I know many have all metal hangars with maybe that white blanket type insulation, I feel the need to stick to good old fashioned stick framing and then interior finished with OSB. Now you can put any new picture up with a staple gun, simple. My one bare concrete wall that adjoins my shop foundation just got framed over, insulated, and sheeted this winter, mostly because I was running out of wall space and didn't have stapler that worked on concrete. If I had a metal hangar I'd have to throw some framing up just to hang some OSB just for picture hanging, it would be easy to do.
I just got through last fall building a crane "hangar" in town on some commercial property I bought. Just big enough for the crane and any newer one I might aspire to, 14'H x 40' long and 18' wide. I wanted to keep it heated, that was a given, but mostly just keep it in the mid 40's to lower 50's at most. After briefly thinking about it I went full concrete foundation as per a house, with perimeter foam insulation well below grade and an insulated radiant heat floor slab. Stick framed and OSB up to 8' on the inside, tin roof and walls. I'm heating with a 2500 watt electric boiler with the thermostat IN the slab, and set at 50 degrees. There is a reason most homes are stick framed and sit on a concrete foundation, they work well thermally and are cost effective. Pole barn types and metal buildings are great also, until you want to keep them warm or cool, just like a mobile home compared to a house on a basement.
I don't have a beer fridge or many of the extra's you guys mention, but then again the shop is right upstairs and the house 35' away so I kept the hangar pretty business like, other then some tractor implements, a small flat bed trailer, and a little lumber that's all. As a result I built it just 28' deep and 40' wide, so cheaper and easier to heat. With my strip it is unlikely I'll ever be flying a bigger plane then something like what I have now plus I have a big shop and other out buildings for junk so I kept the hangar "just right"
Re: Hangar Flying
An Aviation clock
SkySteve offline
Aircraft: Kitfox
