EZFlap wrote:The entire cooling system operates on a pressure differential between the air intake and exhaust. What I'm saying is that it will take more horsepower/drag/entropy to create an equally low pressure on the top or sides of the cowl than it will to create the equally low pressure on the bottom.
I think you may have written this backwards, but I get your point. With the airplane at any alpha other than 0 deg, there'll be more localized low pressure above the cowling than below the cowling. That makes sense.
But having said that, I'm not going to custom fabricate a new cowl and reverse the baffles to create a top-cowl exit. That's a lot of work and I enjoy flying. Maybe if this was a project plane, or something I had in R&D. It'd be neat to see if there truly is a difference though.
I'm willing to bet that I'll see adequate cooling with functional baffle seals, but we'll see!
Crzyivan13 wrote:Backyard landings.
Shut up.
A1Skinner wrote:Gotcha. So really, cutting the ramp down would help as more air would flow through right? From the picture it just seems that the ramp is a good inch or 2 higher on the right then the left...
That ramp actually is supposed to direct air over the #1 so it can get forced through #3. The problem is that my baffle seals have deteriorated and created a number of gaps and wrinkles near the #3. I did a bunch of research and it turns out this is a problem that other guys have had with the stock RV baffle rubber. Gilbert Pierce had similar symptoms to be in his Clipper (same baffle system), replaced the rubber and fixed the problem. My rubber seals are actually older and probably worse than his were when he replaced his. Hopefully it'll take care of the problem.
We were supposed to link up this weekend for the fix, but my wife had a bunch of stuff she needed help with so I had to cancel. Soon!
