wagonwrench wrote:If you have an older Cessna with the ashtrays, I've taken the ashtrays out and made up aluminum covers and installed the jacks there. Makes use of something that isn't used anymore. I can provide pics if anyone is interested.
WW
blackrock wrote:I'll be installing headset jacks soon and the location is still open so I want to ask where peoples preferred location is. It is a four-place and my 1st choice is above and behind each seat in the headliner. Any pro's, con's. or better options?
#1.) I noticed the headset (receive) jacks only have one wire soldered to each of the jacks. That seems wrong to me. (It's like there is no ground wire). I would think there would be two wires, one as a ground and the other to carry the signal. The wires are "jumped" from the passenger 1 jack to the passenger 2 jack - I think "jumping" for the headset (receive) jacks should be Ok, if not necessarily recommended. So, if the headset (receive) jacks should have two wires soldered to them --- what is the connection arrangement? For example, does the signal wire go to the tip? Ground wire to the barrel?
#2.) The mic (transmit) jacks are also "jumped" from passenger 1 to passenger 2. I'm told this is wrong, makes sense to me. The PM-501 has pins for passenger 1 and passenger 2 mics and the ground for each mic to a common pin. I had basically the same questions (as above) for these mic jacks --- what is the connection arrangement for the wires to the mic jacks? Signal wire and ground wire to tip, barrel or ring?
#3.) And finally, what do I do with the shield? I think that it should not be connected to anything at the jacks in the rear seat. So does the shield get connected to the common ground pin on the intercomm?
Thanks much!
wannabe wrote:Has anyone else had a problem with a "mono" head set being plugged into a stereo jack, and causing the intercom to go dead unless ya pulls the mon headset plug out one notch ?!?
