Backcountry Pilot • Heated Seats
Heated Seats
25 postsPage 1 of 21, 2
Heated Seats
Anyone have heated seats in their plane? Been kinda cold here lately and I have been enjoying the heated seats in my wife's car. I've been wondering if they would be worth the weight to have them in the plane. They weigh about 1lb per seat according to the specs I've looked up.
Re: Heated Seats
What about a seat heating element hooked up to a Anti Gravity battery with a switch?
fat tire bob offline
Re: Heated Seats
Sounds great! What about a stick heater!
WilgaBeast offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... OvNBuHnxKg
Cory Robin
PZL 104 Wilga 35 'WilgaBeast'
http://wilgabeast.com
Re: Heated Seats
WilgaBeast wrote:Sounds great! What about a stick heater!
You must drive a Ford. A grip heater off a snowmobile would probly work.
Re: Heated Seats
Heated seat: Plug in to your cig lighter.
https://www.google.com/webhp?sourceid=c ... s&tbm=shop
Clay offline
ceh
Re: Heated Seats
Whee,
I put seat heaters in a Husky I flew a lot in northern and interior Alaska. I loved them. Simple installation......since the seat cushions are removable in the Husky (velcro attach), adding a couple of the seat heat pads was just adding to a temporary installation. Peeled the covers off the cushions, glued the elements onto the foam, and re-installed the seat covers and ran the power wire out through one side of the cover.
Had the mechanics run electrical lines with "standard" outlets located on the side panel beside front and back seats, and voila! Electrical outlets were a minor alteration, and the seat heaters were a temporary installation.......
They sure were nice on those brisk -30 mornings, heading out for a moose survey.
The ones I used had switches with three settings: Off, low and high. We found that high was great first half hour, after which most folks wanted them on low.
I'd do it again in a heartbeat.....if I had an electrical system.
It might be a little more complicated to install them in an airplane with moveable seats.....figuring out the wiring and all.
Re: Heated Seats
I don't, but plan on adding them when I do my seat upholstery. I think it'd be awesome, but it gets cold up in Canada.
Re: Heated Seats
Just run a wire from a spark plug back and thread it through the seat fabric on top, put a momentary switch on it and every time you get cold, hold the switch down as long as you can :shock: , sure it will warm everything up!! :lol:
M6RV6 offline
Re: Heated Seats
Is heated clothing an option you would consider? I would be interested to try something like this.
http://www.aerostich.com/clothing/heated-gear?limit=all
http://gydesupply.com
Bushveld offline
Aircraft: C172
Re: Heated Seats
A lot of RV folks are doing it, I'm sure a search on Vansairforce.net will yield some tips.
Hoeschen offline
Aircraft: 1956 C182, 2014 RV-9A
Re: Heated Seats
Some googling reveals this:
http://www.flyboyaccessories.com/Flyboy ... p/2505.htm
Looks like you can get them lots of places...Jegs, Amazon, etc. I talked to David over at Oregon Aero and he says they install customers' preferred seat heaters long with the upholstery all the time, but they do not sell any as an option themselves, and only for Experimental aircraft.
Mike, curious what brand/model heater you put in that Husky?
I'm thinking this is a great idea now. Just use a little quick disconnect in the seat base with a pigtail for fore/aft expansion and route it under the floor and to the bus.
Re: Heated Seats
I picked up some heated seat pads from a Menard's store here in the midwest,similar to Home Depot. They were ten bucks each. Wal-mart and other places have them also. Cut one open and get the heating elements out and install into your seats.
Re: Heated Seats
I hadn't thought about heated seats... Sounds like a nice feature!
Re: Heated Seats
+2 on the heated clothing. I have a Gerbings vest and socks that have carried me through many miles on motorcycle in the winter at freezing temps with no windshield. My plan for my experimental build is that heated clothing as my only source of warmth.
M3X offline
Re: Heated Seats
I built...and removed...three different heaters for my kitfox the first winter I was doing the phase one test flights. They were all dog breath heaters. About as warm as a dog breathing on you. Then I bought a Gerbings 12 volt heated vest and plugged it into the plane's electrical system. Problem solved. Yes a heated vest really does keep my feet warm too.
I wear it in the car too when my wife is driving. She controls the heater and likes it cold.
tcj offline
tcj
Re: Heated Seats
Zzz wrote:I'm thinking this is a great idea now. Just use a little quick disconnect in the seat base with a pigtail for fore/aft expansion and route it under the floor and to the bus.
That's what I was thinking.
Heated clothes are nice but I think I'd rather have heated seats. May not work quite as good but they would always be there when you need them.
Re: Heated Seats
I like the heated stick idea,should be doable to a yoke too if you wanted.
Moveable seats shouldn't be a problem. Just need to have enough wire to allow the seat to slide,and keep it out of the tracks.
Pretty much what Zzz said.
MountainFlyerN22 offline
Re: Heated Seats
Zane,
I don't recall the brand of heaters in the Husky. Bought them from an outfit that sells and installs all sorts of automotive accessories. I told them I wanted a quality set, and they were. I think the total cost for two seats was less than $50.
A friend in Europe put me on the idea.....he used Mercedes heat units....dunno what those cost.
Re: Heated Seats
mtv wrote:Zane,
I think it's spelled Mercede$$.
Re: Heated Seats
Just the thought of the seat heater is making me sleepy. I'll heat the seat the old fashioned way, bean dip and exhaust fumes.
moppready offline
