Backcountry Pilot • Help - C180 window latch
11 postsPage 1 of 1
I have a window latch (pilot side) on my C180 that is worn out and needs to be replaced. Niagra Air Parts seems to be the cheapest source that I can find and they run $165 each. Being the extremely cheap individual that I am, I would like to find something that is a little cheaper.
Any thoughts on where I could find used latches or are there autoparts out there that someone has used that were good alternatives.
Thanks in advance for the help!
88H offline
Re: Help
I needed to buy one last year and looked all over the net. Your right, Niagra Air Parts was/is the cheapest. But dang, they went up $20.00 within the last year :shock: .
Re: Help - C180 window latch
Which latch do you have? I can think of three different types off the top of my head
Rob offline
Rob, it is the kind that has the small button on it. You depress it and pull up to unlatch the window so it will swing open.
88H offline
Here is the Niagra Link for a new part:
viewtopic.php?f=7&t=6855&p=88201#p88201
88H offline
Hey Larry
I got some used short bugie cords, $8.95 including shipping.
Do you know Peter @ Skywagon City,(705.484.5667) he'llhave them, but he isn't afraid to charge. Sometimes good, somnetimesnot so good. He will have used ones. Kenny Faith in Sacramento (916.368.1832)will have a fair price on used ones.
\Good luck Gary
shortfielder offline
Second on "Kenny Faith in Sacramento (916.368.1832)will have a fair price on used ones."
Price was more than fair (~$10 IIR).
However, I had to dig through several 4 foot shelves of many, many coffee cans full of the parts.
My stanchion is good, I only needed the "handle".
The Cessna bins had many, many variations; I had to test-fit each one.
Found one that fit the stanchion correctly and had the same appearance (and looked new), but the spur was to long. (many were too short). Was easy to "owner-fab" the spur shorter, works/looks great.
You may need to send him what you need to replace, and pay his people to sort through the piles.
BTW, The handles look like they came from some 1950's GM car.
(For me, I plan never to use the roll-pin to fasten the handle on, the original fell off while flying with the window open.)
HTH,
--Bill
c180bill offline
Glidergeek offline
Aircraft: 1968 P206C
DG 400
No Russ, I think this part. These are the type of latches I have in my 1958 182.
http://www.niagaraairparts.com/
TangoFox offline
Keep the Greasy side down!
I don't know but I have been told 60 somthing Falcon
172heavy offline
11 postsPage 1 of 1
