I have been thinking of how to put together a format for a fun flying event that would even the playing field for all airplanes involved. It would be fun to incorporate all aspects of flying: Load capability, Speed, Short field, fuel burn etc. to come up with the ultimate BC airplane/pilot.
Over here on the coast, we have several grass strips as well as gravel bars, sand bars etc. An example would be: Start at a place that has fuel available. Everyone starts with full tanks. The airplanes would be weighed and weight added (people, Sand bags etc.) to the weight the pilot chooses. The more weight, you carry, the more points you get. Then the clock would start when the airplane took off. You would do three take offs, climb to 1000ft agl and land patterns that would all be measured and totaled. All strips would be optional with different degrees of difficulty. Some "strips" would require bushwheels and borer props for example while others would be state grass strips that just about any single engine could land at. At each strip, you would pick up a "card" to verify that you landed there. If you choose not to land, you would have to circle the strip twice or so to simulate the approximate time it would take to land/takeoff. After completing the circuit, you would land and record your total time, refuel and weigh the airplane again.
So, you would get a great score if: You carried a decent load, had short take offs and landings, cruised at a decent speed, were able to land at all the strips, and burned a small amount of fuel doing it.....all in a short amount of time.
So, now the complicated part. Who is going to come up with a "formula" to make this fun and work. For examples sake, the formula would take into account the difference in cruise speeds of a Mooney and a Super cub, and the fact that the cub landed in several places that the mooney could not but the mooney took less time to make the circuit. Or, the C-185 carried 1000 pounds of "useful load" but burned 30 gallons doing it while the cessna 172 carried 500 pounds but only burned 15 gallons?
Anyway, I don't want to get too complicated, but it seems like a fun way to burn avgas and see what airplane/pilot can do a little of everything.
Any Ideas to Add........
Oh, and bonus points of Stealhead brought back!
