High res sectional chart images
http://aeronav.faa.gov/index.asp?xml=aeronav/applications/VFR/chartlist_sectThis is probably common knowledge, and using something like Skyvector gets you a portal-style viewer, but sometimes I like to open the entire sectional as an image on my giant 30" monitor and just poke around.
Scroll down the page to see a list of links for each sectional. The files are large...60MB uncompressed TIFF.
2855
- Aircraft: Swiveling desk chair
NERD
Actually, that's pretty cool. I had no idea you could just get the FAA sectional online. Nice find Z
2803
Even on a 24" monitor.
Wonderful. Thanks.
rjb offline
173
Vick wrote:Guessing that's where apps like Skycharts Pro pull the chart data?
I'm thinking yes. Don't tell FlightPrep.
2855
Found this while catching up on...certain lawsuit-oriented news:
http://vfrmap.com/
2855
15" screen, direct reverse proportion to you unit!
FloatFlyer offline
438
Jaerl wrote:The VFRMap site is great! Does it open where you are too? It loaded right where I am and I was wondering if it opens where you guys are too?
Totally. Your location can be approximated based on your IP address, which the web server receives when you make a request.
2855
Sun Mar 13, 2011 11:21 am
I like using the sectional chart feature on duat.com, you can enter your route of flight and it will show it on the map. There is also several weather overlays you can display on the map.
3263
- Aircraft: 1957 C-180A
Sun Mar 13, 2011 11:41 am
Zane wrote:Jaerl wrote:The VFRMap site is great! Does it open where you are too? It loaded right where I am and I was wondering if it opens where you guys are too?
Which explains why it won't open over here in paradise.
porterjet offline
776
KSBP
Is there is a site to look at or download Canada's VFR charts?
Ipad USA sectionals = $75
Canada = $225
Freedom isn't free.
wyomingiswindy offline
252
- Aircraft: RANS weight-shift machines
Jaerl wrote:That's scary! Guess I better quit sending letters to the White House.
Really, I had an address for the White house for a while and I used to send GB, Hillary jokes.
Hmm, you think you have Drones flying over your house?
5297
