EZFlap wrote:BCP member 182STOL has used the big Demers droop tips, and reported they work, but he did remove them from the airplane for some reason I'm not sure. Check with Bill to learn more.
An often-heard reason for removing the Demers droop tips is the decreased lateral visibility that they incur.
Mine caused me to make a precautionary landing one time. During climbout, I looked over and saw clear fluid sheeting off the right wingtip. Playing with the bank angle and the fuel selector had no effect. Once on the ground I discovered that there is a small drain hole at the aft end of them which I had not been aware of. Turns out they can hold a considerable volume of rainwater if the drain hole gets plugged.
-DP
