After having my first flat tire, luckily at my home airstrip, I am trying to find an idea or a tool to jack up a wheel. Is there a very small, lightweight jack available? It would only have to lift a few hundred pounds on my airplane. A bottle jack is too large. Any jack would have to fit under about 5.5 inches. An extensive Google search has not turned up anything. What do you guys use? It would be nice to find a small rubber bladder to inflate and lift the wheel using a small air pump. Then some tire irons and a new tube and I'd be set. I'd hate to have a flat in the backcountry.
he took care of everything. No more flats. I keep his number handy in case it ever happens again.
