whee wrote:aktahoe1 wrote:Also no disrespect here but I am not certain I agree with the square root / tire pressure concept. Where did that come from anyhow?
It is Horne's Equation. Used to predict the hydroplaning speed of aircraft tires but it doesn't really apply hear because of some of the assumptions made. You can read about it here : http://www.nlr-atsi.nl/downloads/hydroplaning-of-modern-aircraft-tires.pdf
Guess my "friend" will have to find someone to give him a lesson on skiing. Lots of gravel bars around here that are long enough to land but pretty marginal for takeoff.
I respect your opinion Rob and agree with the landing part but if skiing speed can be reached before you hit the water on takeoff then I don't see why it would be a big deal even on small tires.
Gonna post the vid of the departure in a bit but will only leave it active for a couple hours to protect my friend from his wife...
Terry wrote:I watched the vid, looked like a Maule, Whee flys a Luscombe.......so it had to be one of his buddy's.
robw56 wrote:I think the margin for error is just too small when you're playing on the water with small tires.
There would be no accurate way to assure you have enough distance to reach hydroplaning speed before you hit the water.
I'm not a guy who is afraid to ski on the water, I've done it many times on bushwheels and 8.00x6s. But I've also inadvertently used water for takeoff before and it scared the shit out of me! I was 18 and flying my dads 125hp C-120 on 8.00s. I was dragging a beach to feel the firmness of the sand with the intention of going around. The sand was a little softer than expected and slowed me down quite a bit. I applied full power for the go around but ran out of beach before I hit the water. I was on the water at least 200 feet before I got airborne. I think if that plane had the C-85 I wouldn't have enough power to overcome the drag of the water and I would have been swimming to shore. After experiencing that I would NEVER plan to use water to takeoff with small tires. Even the thought of it on bushwheels still scares me.
robw56 wrote:I wish I could remember how fast I was going, but that was about 10 years ago when it happened. I guess there's only one way to find the information you seek. It will be an expensive question to answer though
whee wrote:My buddy estimates he hit the water at about 50mpg
whee wrote:[Guess my "friend" will have to find someone to give him a lesson on skiing. Lots of gravel bars around here that are long enough to land but pretty marginal for takeoff.
Battson wrote:whee wrote:My buddy estimates he hit the water at about 50mpg
We have to think about our fuel economy now, to learn how to hydroplaning the wheels?? Too complicated for me I think![]()
(trolling ends)
Battson wrote:I do have an actual question:whee wrote:[Guess my "friend" will have to find someone to give him a lesson on skiing. Lots of gravel bars around here that are long enough to land but pretty marginal for takeoff.
I am used to hearing it the other way around. That is, you need more to room to land than to get airborne again, STOL comp numbers & other experience etc.
Does riverbed gravel have that much extra drag that you get in heaps shorter than you get out?
Maybe I am just too used to slippery grass.
whee wrote:In low hp planes like I am talking about it typically takes longer to takeoff than land. Higher hp planes it can be the other way around.
Users browsing this forum: No registered users and 20 guests
