Nosedragger wrote:There's plenty of test questions about composite flight plans but I've tried to file one twice now and nooooo, you have to file a seperate vfr plan and open your ifr en route. The reason I wanted to do a composite is to be able to pick up a clearance by phone from the ground and be done. Trying to copy a clearance while hand flying a hold is no fun especially if they change it up. Is there another name for it? I know some flight service operators don't recognize a round robin either.
rw2 wrote:Nosedragger wrote:There's plenty of test questions about composite flight plans but I've tried to file one twice now and nooooo, you have to file a seperate vfr plan and open your ifr en route. The reason I wanted to do a composite is to be able to pick up a clearance by phone from the ground and be done. Trying to copy a clearance while hand flying a hold is no fun especially if they change it up. Is there another name for it? I know some flight service operators don't recognize a round robin either.
Someone asked this question recently on PoA and the consensus was "learn it well enough to pass the written, but you'll never use it in real life".
No one gave an actual answer.
Call your local FSDO? My guys love helping with questions like this.
The reality is that you'll get amended clearances pretty regularly anyway, so you may as well get practiced at writing while flying. I just fly the airplane and write without looking at my pad, trusting that it will be good enough to read. 80% of the time that's the case. I don't have any compunction about requesting ATC read it again in the 20% case.
Nosedragger wrote:Thanks. I am getting better at writing on the foreflight notepad with my #1 booger hook.
