. Plus I'd fill my my BushBag and various jugs, another 30 gallons.Right about the time I heard about the new source for real gas, I had gotten rid of my '92 Ford flatbed (gas, 12 MPG), and got a great deal on a low mileage 12 valve '97 Cummins diesel, one ton no less. Only 271 K! After swapping beds with another forum member here (thanks Jeff), I realized I needed another large tank, a fuel getter. I got a good deal on a 250 G tank, with a stand. I remade some of the angle from the stand for a base when carried in a truck bed. Now I had a secure way to easily move 250 gallons (and I'll probably pack the one clean 55 G drum I have, so 300 total) at a time, in a rig that gets over 20 MPG.
Still, being the frugal bastard I am, I waited until I needed a load of fencing material from a town N of Idaho Falls, so then I would only go 3 miles out of the way to get the fuel loaded. I got a great deal on the fencing also! Once home I tried to defeat the law of gravity, but once again, couldn't. I could only get half the fuel to syphon, so, remembering I live on a mountain side I installed a pipeline. Using some 1" copper tube (from a decommissioned hot water solar setup) I ran it along the hangar soffit so I could park up on my upper level and easily gravity flow the entire tank. Using real gas hose, with the bonding line, I think it's pretty safe. The dump bed is partially raised to get all the fuel out.
Now I have a tank I can carry in my pickup, or on my trailer, or even on the bed of the boomtruck if I have a job up that way. At 3 to 4 GPH for the Rotax, it's a significant amount of fuel. Once empty, I use the shop ceiling trolley to get it out of the truck and have the room to store it from the ceiling. Today was the first entire run through of the new procedure, and it worked great.
