Looking at the following video got me curious how much side slope others on here are comfortable with for off airport operations and why?
http://www.youtube.com/watch?v=903ndLI0nLY
8GCBC wrote:The 8GCBC can crossfeed fuel to the point of be coming very unstable on a lateral slope, being my experience with the 70 gal tanks. I believe it crossfeeds through the crossover vent, but I need to call the factory to see if there are check values and/or to understand why. I always shut the fuel off if she is lateral tilted during parking or moored. Crossfeeding could sink a seaplane from what I am told.
A1Skinner wrote:8GCBC wrote:The 8GCBC can crossfeed fuel to the point of be coming very unstable on a lateral slope, being my experience with the 70 gal tanks. I believe it crossfeeds through the crossover vent, but I need to call the factory to see if there are check values and/or to understand why. I always shut the fuel off if she is lateral tilted during parking or moored. Crossfeeding could sink a seaplane from what I am told.
Will it not cross feed with the fuel selector off? I am pretty sure my 7GCBC will. The fuel shut off is down by your left leg, but the crossover line runs across up top, above the selector. Not 100% sure on this, as I hardly ever turn my fuel off.
onefitty wrote:Majority of check valves in fuel vent systems have a very small hole to allow pressure to equalise, not large enough to cross feed significant quantities though, but the valves can leak when the get full of crud.. Usually goes through the selector valve
A1Skinner wrote:I don't think it was a mistake. I'm pretty sure the crossfeed is above the fuel shut off, so it will crossfeed even with the fuel shut off. I know my 7GCBC crossfeeds at almost any angle. And if its too much of an angle it will start dripping out of the vent. But with 36 gallons it doesn't affect it as bad as 70. Still don't like flying with one full and one empty, me thinks that would be a bad idea.
David
8GCBC wrote:
Pretty sure I turned fuel off. It probably was the cross vent thru the front cockpit, which transferred the fuel.
Users browsing this forum: No registered users and 27 guests
