Backcountry Pilot • Husky drivers
Husky drivers
5 postsPage 1 of 1
Husky drivers
I need some info on Husky planes, How do I remove the spades from the ailerons? How is Aviat about parts supply and cost? Is there a source of used Husky parts around?
Whatever info you may have I would appreciate.
Thanks
Shane
shorton offline
Aircraft: Stinson 108-2
Re: Husky drivers
Best source of information is flyhusky.com: http://www.flyhusky.com/Welcome.html You have to sign up to post, just to avoid spammers.
In short, you cannot legally remove the aerodynamic counterbalances from the Model A-1, A-1A, and A-1B Husky ailerons. They are there to lighten stick forces, and in any case, you DON'T want to fly without them. They are like power steering. They are also called for in the Type Certificate, so without them, the airplane is not airworthy. The Model A-1C (and all B models since spring of 05) have a completely different aileron system, and no counterbalances are used in that wing. It is a MUCH nicer wing, and aileron system, but nothing like the old wing, other than the airfoil shape is the same.
Aviat can sometimes be a bit slow getting parts to you. That, unfortunately, though is true of many if not most small airplane manufacturers. In fifteen years of flying Huskys, and around 4,000 hours in three of them, I never had an airplane down for more than a day or so for lack of parts. That may not be a universal response to that question, however.
Like most manufacturers of light ga aircraft, parts are not cheap. That said, buy some Beech or Cessna parts, and your definition of cheap may change as well. There is no such thing as cheap airplane parts, even used ones.
There are not a lot of used parts available for Huskys. They've only been built since the late 80's so most of them are relatively "new" compared to a lot of airplanes, that is.
They are great little airplanes, and since they are all relatively new, most folks find that less maintenance is required than for many much older airframes.
Re: Husky drivers
Thanks MTV, I don't want to remove the spades to fly, just to get in around the base of the stems to stop some corrosion.
SH
shorton offline
Re: Husky drivers
Hi Shane,
Give Dee Wygant of Copper River Airmotive a shout. He has recently "breathed new life" into a couple Husky wrecks and may have a some spares and left overs, he can answer your spade question as well...he knows his way around a Husky wing well.
http://www.crairmotive.com
Take care, Rob
Rob offline
Re: Husky drivers
.another good thing they are good for is trimming back the brush and tree limbs on the narrow bush strips. They work like knives out on the end of the wings. (that is, if they are on the outside of the ailerons, like scouts).
5 postsPage 1 of 1
