1_Robert wrote:Thanks for the reply. I guess I'm pretty thick as I'm still confused. My iphone has GPS but Garmin Pilot loses my location once I get up a certain altitude. This is one of the reasons I bought the InReach since my understanding is it provides a supplemental GPS source that works at altitude. I noticed the day that I tried using my phone's GPS, Garmin Pilot showed my location at circuit altitude, but it was lost when I later climbed a bit.
I didn't realize our device's GPS were reliable. Perhaps my phone was just having a bad day when I tried it..?
GPS is satellite-based, so there's no possibility that climbing to higher altitude caused your GPS reception to degrade. There's something else going on if you're actually losing position information at altitude. Are you sure you enabled "Location Services" on your iPhone so Garmin Pilot is allowed to access your iPhone's GPS? You can confirm that in the Settings app. Scroll down to find the "Garmin Pilot" entry, and ensure the "Location" option is set to "While Using the App" or "Always". The "While Using" option allows GPS access to Garmin Pilot while you're using it, but disables it (preserving battery life) when you exit the app. The only reason to set it to "Always" would be if you habitually turn off your iPhone or iPad while in flight, and want it to be able to quickly display your position when you turn it back on. Oh, and while you're in the details for "Location" setting, make sure you have the "Precise Location" option enabled as well.
Back to the GPS "accuracy" discussion... Both the iPhone and iPad use a "single-chip" solution that supports both cellular and navigation systems. The "GPS" receiver actually receives from all four of the major sat-nav solutions: US GPS, Euro Galileo, Russian Glonass, and Japanese Quasi-Zenith (which only works in very close proximity to Japan, so moot point for us). Ironically, that makes your iPhone and/or iPad less likely to lose position and navigation capability than a "certified" onboard GPS system designed 10-15 years ago, which listens only to the US-GPS satellites...
I also have a Garmin inReach (mine is the Mini), and I occasionally connect to it just to confirm the GPS will work in an emergency (it does), but I don't actually use it that way very much. Any time you connect to an external source for GPS, you're going to be using wireless to do so – either Bluetooth or Wi-Fi – and both of those use some battery power to operate that radio. Ditto for in-flight use of cellular signals – only it can be a LOT worse, because you can "see" multiple towers, and the system is constantly trying to determine which tower is "best" and switching to that tower. All that takes a good bit of power to accomplish, whereas the internal GPS chipset is highly optimized to use minimum power while still providing good location information.
In fact, all three of those radios (cellular, Wi-Fi, and Bluetooth) use a LOT more power when they are searching for signals than they do when "connected"... That's why ForeFlight (and others) recommend that you use "Airplane Mode" while flying, then individually turn on only the radio(s) you're actually using to link to your GPS or ADS-B source.
