I had an interesting situation the other day. The receipt left in my airplane by the fuel company had written in the "product" box, this:
"Jet A"
Yup. Jet A. In my 152.
First, I call the fuel company -- I get a promise that it was a mistake in writing the receipt, not a mistake in the actual fueling. Now, I know the odds are near infinitesimal that Jet A was pumped into my plane, but I couldn't quite shake that super tiny off chance. It shouldn't be possible (different flared nozzle for Jet A, and other procedural precautions), but it still is.
So, of course, I sump it. Blue, smells like avgas. Great!
Well, until I do some googling. Google gave me conflicting results, regarding whether avgas & jet A can blend or if they separate out (water and oil style). Hmm. Sump it again. Looked at it sideways, very suspiciously.
Finally settled on a plan. It was time to science this s***. I had aprox. 8 gallons of avgas in each wing before it was filled. So four gallons of either avgas or jet a was pumped into each wing. Nice 2:1 ratio. I decided to try to simulate this mix, and see if they blend (doubtful) or separate (what I've always heard). If they do separate, then it's a very easy thing to check...just sump it and if it's blue, I'm good. So, I grab a jerry can of avgas I had sitting around and run home and grab a few empty glass jars. Next stop: gas station. I fill one glass jar with diesel and head home for some driveway science.
Fully expecting a beautiful water/oil style separation, just like I've been told many times before, I excitedly pour two cups of avgas into an empty glass jar. The moment of truth arrives, I pour one cup of diesel, and this is what I immediately see:
Well then. What a beautiful blend. The diesel from the gas pump was rather yellowish, so it did affect the color. However, I've heard that Jet A is almost clear...so it wouldn't have affected the color perceptibly. The smell..well, it smells a bit diesely, but not that much. Hmm.
In the end, I found that the only good indicator of diesel/jet-a presence was texture. The texture of my little blend was significantly oily, whereas the fuel I sumped out of my plane was not. So it was just an error in writing the receipt.
HOWEVER...I had always thought that I could detect an inadvertent Jet A fueling by sumping, since Jet A should settle to the bottom of Avgas. Not so.
