Blue&Yellow Luscombe wrote:The problem with car gas is ethanol. We all know it must be avoided like the plague, but has anybody experimented with mixing water with gasoline with ethanol, shaking it around, and draining the ethanol/water mixture?
RobBurson wrote:I am looking at the same problem. In Oregon I have been told is going to year round 90% UL gas 10% methanol.
qmdv wrote:
Texas Skyways makes a motor for my 182 that will work on 85% ethynol with no change to the airframe. If it will work on 85% then why not 10%. Probably because EAA or Peterson have not done the work yet.
it takes 130,000 btu of coal to make 80,000 btu of ethanol
mtv wrote:Before you add water to auto gas to try to remove the ethanol, bear in mind that GASOLINE can also hold some water, both in suspension AND entrained(in solution). And it is very difficult to remove entrained water.
180Marty wrote:I'm thinking the reason the FAA doesn't allow 10% ethanol is because there are too many people like RobBurson and Mr Scout that don't know the difference between ethanol and methanol. .
Ethanol plants do however add methanol to make it poisonous so they avoid the fed tax.
I agree they have come along way on there formulations but since its a proven fact that it takes more btu to produce than it gives back, its only another welfare program.
I bet that Toyota gets great mileage to.
180Marty wrote:Sorry if I'm wrong about your use of ethanol in the tractor. The guys that irrigate desert to grow corn are the ones that make ethanol look inefficient
