X2Mark Y. wrote:I also put a dab of high temp silicon to hold wire from vibrating on cylinder base and a dab on clamp screw to prevent from turning. Great product
I mounted both my heat pads on the bottom of the pan, I figured heat transfer would work best that way.
Pinecone wrote:Mark Y. wrote:I also put a dab of high temp silicon to hold wire from vibrating on cylinder base and a dab on clamp screw to prevent from turning. Great product
We safety wired my worm gear hose clamps as called out in the Reiff instructions.
I remembered this because after I complimented my engineer for the added touch, he looked at me over his glasses with raised eyebrows and pointed to the text and photos in the instruction sheet!![]()
