IO-360-A1A RSA 5AD1 Servo Shop?
I have an IO-360-A1A with an RSA 5AD1 FI Servo. The engine was running fine when removed in favor of another engine and I'm now going to put it on my project. The engine has been sitting for awhile so I'd at least like to send the servo in for a bench check. Can anyone suggest a shop to perform the check? I'd really like to find a shop that is sympathetic to experimental in case we end up having to go deeper.
Also, I plan to run automotive fuel. Are there mods that make it, or any of the other fuel system components more Mogas friendly?
Thanks in advance.
D.A.
o4abushmaster offline
30
Don at Airflow Performance is great to work with. He overhauled my setup for my Vans RV8, and set it up to run on ethanol.
http://www.airflowperformance.com/
lancef53 offline
402
lancef53 wrote:Don at Airflow Performance is great to work with. He overhauled my setup for my Vans RV8, and set it up to run on ethanol.
Thanks. That's better news than I had hoped for. I thought I had heard there were specific fuel system components that you could use if you were going to run automotive fuel, but I had no idea you could actually set it up to run ethanol. Awesome!
Thanks!
30
