I have an interesting situation I would appreciate some input on… I recently relocated my Cessna 205 from Philadelphia to Seattle on an awesome 40-hour sightseeing adventure, everything went smooth and the plane performed great! After getting to Seattle, on my second flight from the new home base, I developed issues that manifested initially as fuel flow reductions.
In flight after about 45 minutes at altitudes of 1,500 or less I noticed the fuel flow slowly reducing to about 10 gph indicated. Enriching the mixture had no effect on the indicated flow and a reduction in power was felt. I turned on the boost pump and switched tanks and flows climbed slightly, I made an immediate precautionary landing at KBFI where their ARFF tends to be very eager and I was escorted to parking by fire trucks, ambulances, and airport vehicles. Awesome welcome to my new home.
I parked the plane for the night and went back the next morning to see if somehow this was a vapor lock issue I’ve heard about more commonly on the T210 models. Start and runup were fine, but upon rolling on the runway as I get above about 2100 RPM advancing throttle the power drops off significantly, I abort and head to the ramp again. Under the cowling I find that the injectors on the front two cylinders are loose and the distributor has a slight leak from the weep hole. Yesterday I finished replacing the distributor and re torquing the injectors and set out for a flight again. Same issue, getting towards full throttle the engine loses most of the power, reducing to about ¾ throttle restores power to what I’d expect at ¾ power. Even at full throttle and mixture full rich at sea level, indicated fuel flows never get above 12 gph, 22gph+ is normal.
At this point my brand new to me A&P suggests replacing the mechanical fuel pump. I don’t have any other guesses, but thought I’d post here and see if anyone has ever heard of similar issues or has any guesses…
