This was sent to me so I thought I’d share it.
The counterpoint:
https://www.advancedpilot.com/articles. ... cleid=1838
dogpilot wrote:The thing with leaning is you can get to detonation. That is the roughness you feel when you over-lean. Gasoline is a very explosive substance, so much so, one of the largest and most destructive non-nuclear bombs is the fuel air bomb. So detonation is an explosive combustion instead of a wave front. It can, if it gets severe do all kinds of things, like bend rods and so on. You would have a whole host of symptoms if that was the case. I'm not a piston guy by any stretch of the imagination, I'm a turbine guy, but my ex-partner was a guru of all things gasoline. So my learning is on the order of the intellectual Robin Hood, steal from the clever and give to the not so. It is all what I observed around my shop, which had some very talented engine guys and what they shared with me.
Yes you could have that movie worthy hairline crack developing on some critical component at some point of lousy timing over long stretches of pointy rocks. But every engine has that potential. As my ex-partner in Islena Airlines, Arturo once said why not fly it (a Birddog) over the Gulf of Mexico to Key West, "the engine don't know its over water." He did pose the question, would you rather ditch or lose an engine of the Yucatan's triple canopy rain forest, only 300' to fall after you hit the tree tops? I flew it over the gulf.
So don't overthink it, you did an inspection, looked good.
mtv wrote:I agree with dogpilot. Detonation is what Lycoming is worried about. Detonation is certainly nothing to trifle with, and it is at least theoretically possible to achieve same by IMPROPER leaning. That doesn’t mean that PROPER lean of peak WILL cause detonation. Their point is simply that the margin for error when LOP is not as great.
When operating LOP, you really need to be carefully monitoring engine parameters constantly. So, altitude change, or other change can push the engine into dangerous territory. At least theoretically.
I’ve run Continental fuel injected engines LOP quite a bit. And, with a good bit of healthy paranoia. Because Lycoming says they don’t want you to run their engines, I figure that’s good enough for me. I assume they know quite a lot more about the subject than I do.
A1Skinner wrote:mtv wrote:I agree with dogpilot. Detonation is what Lycoming is worried about. Detonation is certainly nothing to trifle with, and it is at least theoretically possible to achieve same by IMPROPER leaning. That doesn’t mean that PROPER lean of peak WILL cause detonation. Their point is simply that the margin for error when LOP is not as great.
If you read the rebuttal that was posted it really shows the opposite of what you are saying. Even by looking at the power charts on the initial lycoming document it makes sense that 50 ROP is worse then 50 LOP. 50 ROP produces higher CHTs and pressure, which actually gives a narrower margin for error the running LOP...
Sierra Victor wrote:A1Skinner wrote:mtv wrote:I agree with dogpilot. Detonation is what Lycoming is worried about. Detonation is certainly nothing to trifle with, and it is at least theoretically possible to achieve same by IMPROPER leaning. That doesn’t mean that PROPER lean of peak WILL cause detonation. Their point is simply that the margin for error when LOP is not as great.
A1Skinner that’s my conclusion as well.
George Braley/GAMI and John Deakin have provided a lot more data and evidence to back up their side of the argument than has Lycoming, in my estimation.
Both however seem to also provide quite a bit of rhetoric, which isnt helpful.
My experience w LOP ops kinda showed the opposite Mike. Once I figured out the settings it was a fairly simple process: take off ROP by the book, climb by the book then set up cruise by the book, and finally pull the mixture to the pre determined FF. CHTs were always 30-40 degrees lower than ROP.
Need to climb? Simple as running ROP. Go right to left: cowls open, mix in, prop in, then throttle. Piece of cake.
You make it sound complicated and I respect you so I wonder what I’m missing.
A1Skinner wrote:I agree SV. The experience here is invaluable.
Mike, on the engine that had a catastrophic failure on you, were you running it LOP or IAC with manufacturers spec?
