Backcountry Pilot • It's not a backcountry airplane. BUT...
5 postsPage 1 of 1
I am just finishing up an avionics upgrade on my RV-7 (I know, two projects at once is a lot), and I went with the Dynon EMS-D10. For those of you working on an experimental, Dynon makes this a pretty easy install and the config only took about 20 minutes. The harnesses provided was easy to install. Assuming it all stands the test of time, I'd do it again.
Here are all the gauges that the one instrument replaced:
Here is the install:
Cheers,
Jim
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
Looks great Jim!
Is that a 300XL in your avionics stack? I thought about putting either a 300xl or a 155xl in my plane.
Re: It's not a backcountry airplane. BUT...
whee wrote:Looks great Jim!
It's a 155. I thought about changing it, but it works so I'm gonna leave it.
jaudette offline
Vans RV-7a
Whee I have a 300XL I would be willing to part with. Also have a KX155 GS with indicator.
gptc offline
Thanks for the offer but I don't think I will be adding anything right away.
5 postsPage 1 of 1
